Ge washer tl1103pbwn
Mashie spills water under tub
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
  • 57 Answers
SOURCE: Water will not stop filling tub.
the problem is that your pressure switch is not working properly. if you take the screws out of the back of the head you will find the pressure switch. first unplug the washer then undo the hose from pressure switch. blow trew the hose, then blow into the pressure switch if you hear the pressure switch click then re assemble and try again put on small load and watch if fills almost to the top or over flows replace pressure switch
Posted on Feb 25, 2009
  • 40 Answers
SOURCE: kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Posted on Mar 07, 2009
beltronic205
  • 1474 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
richroth
  • 9472 Answers
SOURCE: 2008 GE PROFILE WASHER. THE WASHER WILL RUN
You need to replace the "lid switch". Here is a link to the part you need. Here is a link to a video that may help you.
Posted on Dec 02, 2010
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
Ge washer leaking
The solution depends on the age or vintage of your machine.
On the old style machine,weighs about 300lbs, leaking is caused by a release port in the pump assembly. Its located above the motor in the rear right corner of the machine.
On the newer version of the machine, often with a white mantel and about 100lbs. Leaking of often caused by a poor brake. When the machine is in wash the brake holds the tub from spinning, however whent hat brake is weak the tub is allowed to spin in the wash cycle causing water to spill over the top of the tub and to the floor.
Its hard to say what the problem is without knowing more but a very basic guideline would be, if its from the pump you will be seeing a small stream coming from under the machine. If its the newer version it will be alot more water.
You should be able to replace the pump yourself, the brake repair is both very involved and can be more costly and should be done by a technician.
Hope this helps, take care
Nov 23, 2010 | GE Washing Machines
Water is over filling the tub, and spilling all over the laudry room floor.
this sounds like a ge ? if so you need to remove front cover between the top and the front cover you will see a small gap on both sides you will have to put a putty knife in about 2" from the ends and push in
once removed on the left side of tube you will find a small rudder hose pull the hose of clean in side of hose with small screw driver also fill washer with water with hose of untill water leavel is to the center of the box now use a turky baster to force air in to tub by placeing baster over the stem wher the hose was force air in to tub fill washer a lititle more untill water shots out of stem stop washer and drain all the water out cut about 1"off hose reinstall stop useing liqid soap
Jan 30, 2010 | Washing Machines
Soap-not residue-still on clothes
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
Nov 12, 2009 | Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Jan 23, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
