Question about Abbott Laboratories CELL-DYN 1800 Hematology Analyzer
HOW TO SOLVE PRESSURE LEVEL TIME OUT
PRESSURE LEVEL TIME-OUT
I have an mr2 roadster 2003, the engine is turning over strongly but sometimes takes a long time to fire, it also idles high for about 5- 10 mins and smokes from the exhaust during this time. Any help
check oil level first then if more than qt low bring up to full level them check oil pressure on gauge as cranking car or oil light make sure these things are operating correctly if not this is problem no oil pressure then computer delays starting is this white smoke or black smoke or blue smoke?
May 28, 2011 | 2000 Toyota MR2 Spyder
C-50 Boulevard. My oil light won't go off. Motorcycle has proper oil level.
Do not run the motorcycle with out oil pressure. Fortunately, most of the time it is the oil pressure sender that is the problem. Locate the sender underneath the motor toward the front (single wire $28) and replace it with a new one. This should solve the problem. If it does not you may have to dig deeper and replace the oil pump ($125)or find the source of the oil leak. On the rare chance that the pressure relief valve is stuck open ($40). As always start with the cheap items. If you drove it home with the oil light and the cycle still runs OK then you probably just need a new sender.
Apr 11, 2011 | 2007 Suzuki Boulevard
HOW CAN I SOLVE MY PROBLEM BY MY SAMSUNG WA1065D1 , it shows 1E? When I switch it on after a few seconds it shows 1E? Can u please help me?
WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Dec 20, 2010 | Washing Machines
How can i solve the error C6 in a AEG Lavamat
c6 is indicating a fault in the water level sensing . either pressure switch defect. leaking pressure tubes or blockage in pressure chamber that the tubes connect to,
May 03, 2010 | AEG Lavamat 88840 Front Load Washer
Finding the pressure switch and the pressure sensor tube
Water level switch is in the control area right behind the water level knob. There should be a tube conected to it. Follow the tub to the bottom of the tub. If this tube is not connected it will just keep filling. If you find the tube disconnected you will need to reconect the tube and drain the water and try refilling. If this tube is conected the take the tube off of the water presure switch and blow air through it to make sure it is not cloged and reconect, drain water and retest. if this still does not solve your problem your presure switch is probably bad and you will need to change it. every time you test you must drain the water so the tube will get air presure. If the tube has a crack or hose it will need to be replaced.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHING MACHINE IT CONTINUES TO FILL WITH WATER AND OVER FLOWES DOES NOT GO THROUGH AGITATION CYCLE
If the machine is not recognizing the water level, and continues to fill...the pressure switch is most likely bad
With a model #, we can be more exact and point you toward a replacement part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2009 | Washing Machines
When the foot brake is applied the brake lights dont come on unless extreme pressure is applied on 1200 sporster custom.
First thing I'd check is the brake fluid level. I have a "99" sportster and the rear brake switch is pressure driven. If your fluid is up to the correct level I'd adjust your travel on the brake linkage. That should solve the prpblem if not the only thing left is to replace the pressure switch located on the left side of the bike above the swingarm.
May 04, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Motor oil
change the oil pressure sending unit on the engine.
Mar 31, 2009 | 2000 BMW 3 Series
Low oil pressure in 1998 camaro ls1
First have your oil level checked and make sure that it is at the right level. If not that's your problem, if your level is good you may have a bad oil pressure switch. This can be checked by using a oil pressure guage. If switch is bad replace and solve the problem. However if your vehicle has alot of wear and tear on he engine and you were using 20w-50 oil and it was replaced with 5w-30 that oil may be too "light" for the vehicle and you would get a low oil pressure reading. Good Luck
Dec 15, 2008 | 1998 Chevrolet Camaro
Abbott Laboratories CELL-DYN 1800 Hematology Analyzer Logo
Top Abbott Laboratories Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Abbott Laboratories Science and Laboratory Expert? Answer questions, earn points and help others
