Question about Samsung ML-2851ND Laser Printer
Printer squeaks makes odd sound when printing
Printer is making a squeaking sound whenever I print. What do I need to do?
Toner Cartridge is the most common cause of squeaks and easiest thing to try first. Try a different cartridge.
Feb 15, 2016 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Printer squeaks when printing
remove the fuser wiper if the noise is still present remove the fuser and turn by hand. fuser bearings will cause this
Aug 28, 2009 | Lexmark T632 Laser Printer
Can you oil a samsung ml-1430 printer to make it stop squeaking
Yes, lubricate the chrome shaft with light weight oil.
Jul 30, 2009 | Office Equipment & Supplies
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Squeak
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
Aug 14, 2008 | HP Photosmart D5160 InkJet Printer
Squeaking noise when printing
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
Samsung ML-2851ND Laser Printer Logo
60 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
