Question about Powermatic > Drill Press, Model 1200
How to replace belts on powermatic 1200 varialbe speed drill press
4 Suggested Answers
SOURCE: My Powermatic drill press model
Hi, this is happening because the belts are shinny... true.. well and a little stretched... you see what happens is the belts are slipping over the Pulleys when the drill bit draws and bites on it hard.. the Fix if you will, is to A: Replace the belt... Or B: Tighten the belt, & roughen up BOTH surfaces a little to improve traction..
This usually will only be a stop gap measure though, as this really means that you need a new Drive Belt(s) as the existing one(s) has stretched too much, and has lost it's grip. belts only have to increase their size minutely to just loose that edge that a newer one has.
Posted on Nov 25, 2010
al_kupchella
  • 843 Answers
SOURCE: Need a chuck key for model 1140b,f powermatic
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Posted on Mar 14, 2011
al_kupchella
  • 843 Answers
SOURCE: Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Posted on Jun 19, 2012
Change jacobs 33 chuck powermatic 1150a
In most column drillsis a narrow rectangular recess above the chuck when it is rotated slightly downwards
therefore you should have one of these auxiliary tool
At least the wedge
Have not seen another system to remove a drill spindle
Feb 27, 2016 | Powermatic 1150a Variable Speed Drill...
I am considering buying this used drill press. How do I change speeds on this drill?
If the drill press has multiple pulleys, you move the drive belt up and down. Larger motor pulley to smaller drill pulley has higher speeds, and vice versa.
Mar 06, 2015 | Drills
Katie,
Jun 15, 2012 | Powermatic Drills
Need a product number for a Dayton model 3Z235 drill press variable speed belt. Can you help?
Gates 5M1150 Polyflex V-Belt 89021150
This is for a drill press with stepped pulleys. I wouldn't call it a variable speed belt, but it is the belt that I am getting for my Dayton 3Z235 drill press.
May 12, 2011 | Garden
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
Clunking when lowering the spindle
Try checking to see if the front pulley cluster locking grubscrew is tight, I had a similar problem on mine.
Mar 15, 2010 | Powermatic 1140 B,f 14 " Drill Press...
Spring return
paste this link into your browser address bar
http://www.toolsandmachinery.com/powermatic-parts-5882/powermatic-drill-press-parts-6903/powermatic-2800-parts-6904/
thats the diagram and parts listing for the only available powermatic drill press ( 2800) , if its an older model you might find the parts on ebay , i have in the past used a recoil starter spring but it can be a pain to modify the spring to suit .
hope this helps , if it does please vote :)
Nov 10, 2009 | Powermatic Drills
Powermatic > Drill Press, Model 1200 Logo
49 people viewed this question
Top Powermatic Drills Experts
Are you a Powermatic Drill Expert? Answer questions, earn points and help others
