Question about Toshiba e-STUDIO166 Printer
Red key flashing toshiba
Orange key
How to bypass security system in my 2000 Pontiac Bonneville SSE supercharged
Hi the Bonneville most probably has the chip in the key ( GM calls this the vats system) this can be easily tricked by doing this. First u have to know the resistance on the key pellet get a meter and put one lead on each side of the little silver pellet on your key , set your meter on resistance, you will need to know this resistance , (note ) if u have a extra key you can just solder a wire to each side of the key again on the pellet and use this in the next step.
now if you don't have a key take the resistance readings to radio shack and get a resistor that matches close to the resistance readings you got from the key., NOW go under the dash of the car, look at the under side of the steering column for a orange wire (actually its two wires in an orange cover , cut this orange wire , split these wires and strip them . now solder the resistor on the car side of the two white wires in the orange cover, is doesn't matter which wires go where , if you are using the old key method wire the key to these wires basically you are looping the system to believing there is a resistor key in the ignition do not wire anything to the side going up to the steering wheel area these can just stay cut they have nothing going to them after u cut the wires , after the resistor is soldered into the car side of the harness the car should start and u can have regular keys cut
Sep 14, 2015 | Pontiac Cars & Trucks
Rear wipers won't work on 2004 yukon
You need to remove the trim panel inside the back door, Unplug the motor, Be sure you have power on the Orange wire with key on, then test the Grey wire with wiper on, key on and if power? then likely bad motor If NO power on one or both wires at the plug? then fuse for rear wiper or bad switch the orange wire is from the RR WPR fuse in the under hood fuse box.
I doubt the other fuse is bad as if it was, the rear washer would not work So,, be sure power on orange wire, then check power on grey wire with wiper on and key on. No power on grey? bad switch. No power on both orange and grey? likely motor. This is the only way to test the system
Feb 26, 2015 | 2004 GMC Yukon
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
What is orange/red flashing when charging
The color flashing tells you how close you are to a full charge. The orange/red flashing should change to yellow and finally green. Sorry I have an original model so your's might be slightly different. Does it never change from orange/red?
Jul 03, 2014 | iRobot Roomba 550 Vacuum
Network key for orange uganda with alcatel
you can get the Network Unlock Key for Uganda Orange Network Lock at here
http://www.unlocking4u.com/alcatel-unlocking-service-a/rs6wp10/
Apr 12, 2011 | Cell Phones
TOSHIBA DLP 44HM85 - When turn tv ON: Operation indicator flashing orange, turns red. System in STANDBY MODE. How can I get out of it and watch tv?
If you have never replaced the Lamp and the TV is over 2 yrs old,Then its Time you replaced The Lamp.
Mats Electronics had them on sale for $89.00
1-800-628-1118
Feb 25, 2011 | Toshiba Televison & Video
Will not start due to alam system, when i turn the key
your key has a resistor chip in the middle of it and two hair thin wires running to the ignition lock cylinder. there are two ways to fix it yourself, first track the two small orange wires from the lock cylinder down under the dash then A. pop the resistor out of your key and solder it between the orange wires or B. measure the resistance value of the chip with an ohm meter, buy resistors that match that value and solder them between the orange wires.
Dec 24, 2010 | 1994 Cadillac Eldorado
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
Toshiba e-STUDIO166 Printer Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
