Question about Mitel Computers & Internet
When I pick up the headset on the Mitel 5324 phone, a beeping signal sound for about 4 times
  • 37 Answers
SOURCE: Y-JACK headsets with Mitel 5212 ip phone
You can find allot of headsets that will work by googling the set type and the word headset. But I think what you are looking for is found i the programming of your phone system. In the class of service you can have the option for silent monitoring turned on and in feature access code add a code for Monitoring. Yes you are correct this is something for your Mitel vendor complete but i'm sure they would be happy to help.
Posted on Mar 10, 2009
  • 4 Answers
SOURCE: How do you do a
Unplug the power from the phone. Hold down the Down Arrow key, and power it back on while holding the key. You will get an option to default the phone to factory settings.
Posted on Oct 30, 2010
Testimonial: "Cheers better late than never"
  • 378 Answers
SOURCE: my IP mitel phone 5324 phone gives an error
the DHCP server or your network switch isn't configured properly. I hope by now your network admin or vendor has gotten this problem resolved.
good luck,
Mark
Posted on Apr 04, 2011
  • 378 Answers
SOURCE: plantronics cs60 cordless headset not
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Posted on Apr 22, 2011
  • 378 Answers
SOURCE: Headset doesn't work when plugged into Mitel 5215 IP Phone jack.
You need to have a Headset button added and press it... or dial the headset on code. Contact your system admin or vendor to have the button added or to get the codes. This is something you can't do from the phone.
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
Mar 09, 2015 | Mitel 5330e IP Phone 50006476
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
My IP mitel phone 5324 phone gives an error message option 128 missing
good luck,
Mark
Jan 27, 2011 | Mitel 5215 IP Phone
Using it on my Mitel 5330 IP phone. Worked for a long time then started cutting out. Replaced batteries in Vista M22 amplifier even bought a new headset still have same problem
It sounds like you have a short in the wiring. Mitel has their own cordless headset for the 5330 model phone... it is awesome in every way. Battery life, range, clarity, etc.
Jan 18, 2011 | Plantronics HW251N Headset
Handset on Mitel 5340 IP phone with bluetooth has no dial tone but has dial tone on speaker. Bluetooth signal is fine. Help.
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
Jan 07, 2011 | Mitel 5340 IP Phone
How does a regular headset work? I plugged it into the back of the phone, but don't know how to make it pick up...
if the headset is a wireless one there is a button on the headset itself you need to press to pick up or hang up a call. alternativly look for a headset or pick up button on the phone needs to be pressed. this i diffulcult to answer further without knowing the model of your headset.
download user manual for the phone at the following
http://www.tc.mtu.edu/voice/equipment/Mitel5220/5220userguideR4.0.pdf
check page 23 regarding using heaset.
when the phone rings press the headset feature on your phone and then select the ringing line button.
then press cancel to hang up.
I hope this was useful.
Jan 05, 2011 | Mitel 5220 IP Phone
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
OR
Dec 13, 2010 | Mitel 5220 IP Phone
How do you do a factory reset on the Mitel 5324 IP Phone ?
Aug 31, 2010 | Mitel 5220 IP Phone
Jun 30, 2010 | Mitel 5215 IP Phone
Computers & Internet Logo
50 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
