Question about Canon Computers & Internet
Counts Black and White copies as Color
Image Runner C2550
MUKHTAR
  • 2017 Answers
SOURCE: All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Posted on Oct 16, 2007
SOURCE: no color
Make sure the player isn't in PAL versus NTSC.  This is found in the General Setup Page by clicking setup on the remote.
Posted on Mar 31, 2009
EmmettPinger
  • 63 Answers
SOURCE: Need to set default for black/white copies not autocolor
set the machines control panel to the settings that you want and then press the PROGRAMS button and choose set as default and the screen will always be as you set it.., Good luck
Posted on May 01, 2009
  • 13 Answers
SOURCE: What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Regards Mug71.
Posted on Sep 14, 2009
  • 217 Answers
SOURCE: hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Posted on Apr 05, 2010
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
I have a Image Runner C3200 and it is tinting the paper black when making copies
- clean the laser units glass with the special cleaning tool provided with the copier
- check and clean the image transfer belt blade and the recycle mechanism
- check if the tinting is on the imaging unit , if yes change unit if not chevk above
Jul 27, 2012 | Canon imageRUNNER C3220 Color Copier
Canon Color imageRUNNER C2550 legal size copying only works with single pages placed on the glass. Auto feeder ends up with image off center
when you making the copies, you MUST adjust the paper guides on adf/dadf. They are gray plastics left and right from original and can be moved to each other. They guide the paper rightly in adf/dadf.
If these doesn't helps, please describe what happens when dadf pulls the paper inside.
Apr 21, 2011 | Canon imageRUNNER C2550 Color Copier
WHERE DO YOU FIND METER FOR CANNON IMAGE RUNNER 5180
Hello jen,
Look on the operator control panel and you will see a little button below the power button. It says counter. Press it and look at the counter named "101". This counter represents the sheets of paper (regardless of size) that have successfully exited the device. The other counters you see, well, lets just say they are of no value. Now you could have a tech come out and "configure" the counters you see.My company sets the device to display "102"(counts 11x17 as 2 clicks), "109"(just black and white),"124"(color). Have a good day and please let "FIXYA" know I helped you. :-) SPINAL
Mar 18, 2011 | Canon imageRUNNER C5180i Color Copier
Copy of Canon ir c2550 service manual
This Canon ir c2550i has an error e000003-002 which requires shutdown.Appreciate any idea about this problem. Ron
Jan 17, 2011 | Canon imageRUNNER C2550 Color Copier
My Dell Photo 926 stopped printing in color. It prints in black and white. If I make a copy, it can still make a color copy. I'm stuck.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
Jul 19, 2009 | Dell 926 All-In-One InkJet Printer
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
Computers & Internet Logo
35 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
