Question about Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television
Universal remote Old remote no longer works. Tried using a universal remote - got tv code but that didn't work either - not even name brands list NAXA. Where do I get a remote that works with NAXA tv/dvd?
Re: universal remote - Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television Portable Televisions
Call for a factory remote at1-800-736-6837
Posted on Nov 17, 2007
0 characters
3 Points
Remote code for cello tv urc22b
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
Sep 22, 2014 | Portable Televisions
Remote Controller not working, Where can i buy the remote controller for this Sony DVD Home theatre.
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site Check this site too. If you see these sites by "MOSAIC" or "Magazine" view will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops.
Jun 10, 2014 | Sony DAVTZ710 - 5.1ch DVD Home Theatre...
Iview 2200 led tv
If it's a GE universal remote and it doesn't have the brand name iview in the manual with the code then you can't use the universal remote with it. I also have a GE universal remote and no matter which model of GE remote you get they have the same codes. I have never heard of iview so I doubt it will work. You can try and see if there are any original remotes for the iview on ebay though.
Oct 28, 2012 | Iview 352PTV TV
How can I program the U-verse remote to a Emerson tv?
Not likely to work as Emerson (brand name bought and used by another company) uses odd codes that universals etc rarely will even be able to program---
Mar 28, 2012 | Emerson Portable Televisions
I'm trying to find a universal remote that will work my 13" naxa tv
Unfortunately, naxa tv's aren't compatible with universal remotes, as they use a proprietary coding system for their tv's.
Your only hope is to contact Naxa's support department at to ask about replacement remote.
This is directly from their website about the incompatibility with universal remotes.
I know you were hoping you could use a universal remote for your tv, but sadly that's not the case here.
I wish I could have given you better news, but it is the way they designed their sets, that's why universal's don't work.
I hope this helps you out in knowing what to do now, and have a good day.
May 25, 2011 | Naxa Electronics Nx-540 13 in. Portable TV
Remote code for TruTech dw19tt
TruTech is made by Daewoo. I entered Daewoo codes from my digital converter box list. The sixth code I tried made it work (140 for an RCA converter box). Now the Converter box remote will control volume and power on my Trutech DW19. Regards, tmjl.....
Jun 09, 2008 | Portable Televisions
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Portable Televisions
Universal remote code
need coads for naxa tv dvd combo for an rca remote
Jun 26, 2006 | Naxa Electronics NX-517 Television
Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television Logo
658 people viewed this question
Top Naxa Electronics Portable Televisions Experts
Are you a Naxa Electronics Portable Television Expert? Answer questions, earn points and help others
