Question about Brother SX-4000 Typewriter
The hammer does not move
I replaced the ribbon. Carriage goes back & forth. Wheel clicks and move along but it does not type on the paper.
    New Friend:
  • 18 Answers
This problem is the print cam and would require a replacement part you could locate the closes Brother dealer in your area and they should be able to perform the necessary repair. Brother can give you your closest dealer by calling (877) 276-8437.
Posted on Jun 24, 2014
5 Suggested Answers
SOURCE: hammer doesn't strike
Try taking the wheel out and aliging it with the piece in the middle with a hole in it so that the pin and the wheel connect when you push the lever forward to connect the wheel to the disk.
Posted on Sep 14, 2007
  • 86 Answers
SOURCE: My daisy wheel doesn't move when I type and the
no easy fix for this one. take it to a repairman
Posted on Dec 30, 2010
squipps
  • 204 Answers
SOURCE: Daisy wheel will go to
THE TYPEWRITER SOLENOID IS BROKEN. A TYPEWRITER SHOP CAN FIX THIS IF THEY HAVE THE PART.. SHOULD BE LESS THAN $50
HOPE THI SHELPS, SQUIPPS
Posted on May 06, 2011
RadarRon
  • 398 Answers
SOURCE: daisy wheel not moving
Did you remember to push the hammer forward?
Posted on Oct 09, 2011
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Hp 7520 carriage slams back & forth
Sounds like a defective printer that you may need to replace. If you ever need the ink for it, please let me know. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Bought new Brother ML300 will not type anything on the paper, please help!
I would check all the basic stuff first. Is the print wheel locked into position? Is the platen all the way forward? (lever right side) Is the ribbon installed correctly and not cocked up on one side? Do you hear the hammer striking the paper? If you hear the hammer striking the paper, it is a ribbon problem. If you don't hear it, it is a hammer / print wheel problem.
Jun 24, 2014 | Brother ML-300 Typewriter
Hammer doesd not strike
There is a clutch system under the ribbon carrier that has to rotate to move the hammer, see if you can see if this part is rotating, also there is a spring that puts pressure on the hammer. If this clutch is not moving it may need replacement,, or cleaned with alcohol.
Apr 14, 2014 | Brother ML-500 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
The hammer on our typewriter won't strike, it just quit in mid type. Any suggestions? When we push a key, it will not strike the letter for it to print on the paper.
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
Dec 22, 2010 | Brother SX-4000 Typewriter
This typewriter has not been used in years. Every time I plug it in though it starts beeping. Why?
Take the chrome bar that is inside where the carriage is(the assembly the ribbon goes on) and put light weight oil on both sides of it and move it back and forth so it will free it up.There are two bars in it. Put the oil on the bar toward the back and put white grease on the one that is closest to you. This should take care of it. If not make sure the hammer is pressed all the way up against the card scale.(black lever on the left) and that you have ribbon left in the cassette. Kevin
Jul 09, 2010 | Swintec 7040 Typewriter
TA Royal 503 typewriter with a print wheel that is not aligned
Jul 09, 2009 | Royal Office Equipment & Supplies
Hammer doesn't strike
Aug 31, 2007 | Brother SX-4000 Typewriter
Characters fill in intermittently.
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
Brother SX-4000 Typewriter Logo
164 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
