Question about Utilitech Plumbing
Pump will not build up pressure
3/4 hp well is 80 ft deep
4 Suggested Answers
agent91
  • 2100 Answers
SOURCE: 1/3 hp shallow well jet pump (mastercraft brand).
I don't think the power shortage had anything to do with the pump, I think it is the impeller or a gasket, or both. It is hard to say, a pump like that should **** dry and pull water right in.If you put your hand over the end of the pipe, it should make a mark like an octopus on your hand. I would take off the impeller, look for trouble, and replace 3 or 4 parts in there , you should have water. Hope this helps.
Posted on Sep 24, 2010
SOURCE: my shallow well pump will not pump to 40 lbs
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Posted on May 27, 2011
boysor2933
  • 293 Answers
SOURCE: I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Posted on Nov 13, 2012
How many cubic feet in an area 27'long x 3' wide , 3 " deep
Johnathan, 27' x 3' x .25' = 20.25 cu. ft.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jul 24, 2016 | Office Equipment & Supplies
What size is the axel nut on a2006 chevy cobalt front
memory serves says 36mm.....not absolutely pos. though
Dec 14, 2014 | 2006 Chevrolet Cobalt
Pool deep end
you might want to check with a professional to see if you can get a liner to fit that and it will be safe
Jun 24, 2014 | Pool & Spa
How many gallons of water the intex 15x36 pool holds?
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Jul 10, 2011 | Intex Easy Set Pool 15x36
How many cubic yards of material are needed for the foundation of a barn 40 by 80 ft., if the foundation is 2 ft, thick and 12 ft. high?
I'm sorry to tell you but it's actually wrong..
this should be how it drawn..to solved this two volume is needed..the outside and inside volume..12_5_2012_12_36_29_am.gif
V(outside)=80(40)(12)
V(outside)=38 400 cub. ft.
V(inside)=(80-2-2)(40-2-2)(1...
V(inside)=32832 cub. ft.
V(total)=V(outside)-V(inside)...
V(total)=5568 cub. ft
convert to cub. yard=206.22 cub yd.
Jan 10, 2011 | Computers & Internet
I would like to know the torque settings for head bolts on a 454 big block?
Aluminum heads--
Short bolts-65 ft.lbs.
Long Bolts-75 ft.lbs.
If no aluminum heads.....80 ft. lbs.
Oct 11, 2009 | 1981 Chevrolet Corvette
What are the wireless specifications of the 802.11b Wireless Router (F5D6231-4)?
F5D6231-4 802.11b Wireless Cable/DSL Gateway Router Output Power +13dBm-20dBm (50mW) (max.) Range (ft/Meters) 11 Mbps 5.5 Mbps 2 Mbps 1 Mbps Outdoors 590 ft (180m) 980 ft (300m) 1475 ft (450m) 1800 ft (550m) Indoors 50 ft (15m) 125 ft (38m) 150 ft (46m) 300 ft (90m) Reciever Sensitivity -76 dBm -80 dBm -80 dBm -80 dBm
Feb 16, 2006 | Belkin Wireless Cable/DSL Gateway Router
Plumbing Logo
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
