Question about Health & Beauty
What are the side affects of a AB fire extinguisher for someone with a low immune system?
Name and explain at least 6 guidelines for placing of fire extinguishers.
Google is your friend in such cases. Read all the pages and make your own findings.
  • Emergency Standards ' Portable Fire Extinguishers ... https://www.osha.gov/SLTC/etools/evacuation/portable_placement.html Portable Fire Extinguishers Extinguisher Placement and Spacing. ... The following guidelines will help you identify the number and types of portable fire ...
  • A Health and Safety Guideline for Your Workplace Fire ... iapa.ca/pdf/FreeDownloads8_fireext.pdf · PDF file Fire Extinguishers © Industrial Accident Prevention Association, 2006. All rights reserved. 1 A Health and Safety Guideline for Your Workplace
  • Placement of Fire Extinguishers in the Workplace safeandcompliant.net/safe-kb/article.php?id=30 Placement of Fire Extinguishers in the Workplace. KB Home ... The following guidelines will help you identify the number ... Fire Extinguisher Size and Placement ...
  • Portable fire extinguishers. - 1910.157 - osha.gov https://osha.gov/pls/oshaweb/owadisp.show_document?p_id=9811&p... 1910.157(a)Scope and application. The requirements of this section apply to the placement, use, maintenance, and testing of portable fire extinguishers provided for ...
  • Guidelines to the Strategic Placement of Fire ... driftwoodontheocean.com/2016/04/11/guidelines-to-the-strategic... Fire Extinguisher Safety and Other Essential ... of placing the fire extinguishers in the ... to place your fire extinguisher, here are a few guidelines to ...
  • Geeks On Home: OSHA Fire Extinguisher Guidelines www.geeksonhome.com/...7717356_osha-fire-extinguisher-guidelines.html OSHA Fire Extinguisher Guidelines. ... The Occupational Safety and Health Administration maintains rules governing how fire extinguishers are used, ...
  • Fire Extinguisher Requirements and References in the ... amerex-fire.com/wp-content/uploads/2013/02/Fire-Extinguisher... · PDF file Fire Extinguisher Requirements ... there are additional requirements for placement, ... servicing and training with portable fire extinguishers beyond the ...
  • Fire Detection and Extinguishing Equipment Regulations laws-lois.justice.gc.ca/eng/regulations/C.R.C.,_c._1422 ... Fire Detection and Extinguishing Equipment Regulations ... Special Requirements; 7 ... Portable Fire Extinguishers; 90 ...
  • http://www.bing.com/search?q=guidelines+for+placement+of+fire+extinguishers&qs=n&form=QBRE&pq=guidelines+for+placement+of+fire+extinguishers&sc=0-46&sp=-1&sk=&cvid=405F1FDF23E64C4A8BD1FC6B5358AE64
    Jul 10, 2016 | Cars & Trucks
    How is fire extinguisher used
    Pull the safety catch, aim at the bottom of the fire (not the top of the flame), and compress the trigger.
    Jan 31, 2015 | Cars & Trucks
    What is the difference between osteoarthritis and rheumatoid arthritis?
    Osteoarthritis (OA) is a condition that affects the whole joint including bone, cartilage, ligaments and muscles.
    Osteoarthritis may include:
    • inflammation of the tissue around a joint
    • damage to joint cartilage - this is the protective cushion on the ends of your bones which allows a joint to move smoothly
    • bony spurs growing around the edge of a joint
    • deterioration of ligaments (the tough bands that hold your joint together) and tendons (cords that attach muscles to bones).
    Rheumatoid arthritis (RA) is an autoimmune disease that causes pain and swelling of the joints. The normal role of your body\'s immune system is to fight off infections to keep you healthy. In an autoimmune disease, your immune system starts attacking your own healthy tissues. In RA, the immune system targets the lining of the joints, causing inflammation and joint damage. RA usually affects smaller joints, such as the joints in the hands and feet. However larger joints such as the hips and knees can also be affected.
    Sep 02, 2014 | Miscellaneous
    Ulcerative colitis
    Inflamed colon is also referred to as inflammatory bowel disease, colitis, or ulcerative colitis. While there is no set cause for an inflamed colon, the University of Maryland Medical Center states that it can be a result of a faulty immune system response, genetics or environmental factors. When any of these situations are involved, the immune system reacts by causing inflammation in the body, affecting the colon. There is no cure for an inflamed colon, and treatment involves finding a way to ease the symptoms.
    Jun 01, 2014 | Health & Beauty
    What are the different types of fire extinguishers?
    there are 3 types:
    water
    carbon dioxide
    dry chemical
    to learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
    May 07, 2013 | Home
    Hi there. I have just moved in to a flat & have been asked if my stoves 050531075 gas oven is fitted with something called a FSD (Fire Suppresion Device) Would you be able to tell me please?
    The are probably referring to an automatic fire extinguisher system, but from what I just read, the UK only requires a manual fire extinguisher to meet code.
    The FSD would be fire extinguishers mounted on the wall instead of portable. They are only required in commercial restruarants.
    Jun 08, 2011 | Stoves Ovens
    Akai PT5598HD 55 in. Rear Projection
    Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
    Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
    Health & Beauty Logo
    24 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
