Stadt heating Need a new thermostat where do I get one and what will fit and how do I put it on?????
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Main Oven Thermostat :- No control of Heat
Hi
If you cannot regulate the heat in your oven it is most likely that your oven thermostat has failed.
You will need to have a new one fitted. This link will show you whats involved and where to get the parts. ; www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Dec 16, 2010 | Ovens
Our Stadt heater is not working. I have tried to turn the termostat off then turn it back on & that didn't work. I also tried to press the reset button for 5 seconds then turn the termostat back on....
o my friend i hawe a same problem in macedonia it hawe a mystake in elektronk part in airconditioner...and maybe is dthe outside part of split termik is not ok maybe ...
May 20, 2010 | Heating & Cooling
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
Mar 25, 2010 | Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
Feb 12, 2010 | Dryers
Grand vitara radiator over heating
I have had brand new Thermostats that are bad. The way to check a thermostat is to boil it in water and see when it opens. You may need to have your radiator cleaned or roded out. You can also remove your thermostat and see what happens then I would start by flushing the system and see what you get.
May 23, 2009 | 1999 Suzuki Vitara
Put new heater and thermostat in water tank and leaking from the top
You put new heating element in this water heater..Is it leaking from the element or from the pipe fitting?
Mar 07, 2009 | Water Heaters
Thermostat problem
Buy some more thermostat cable with the same number of conductors inside it that you need. Twist the wires in the wall to the conductors on the new cable you just bought. Wrap the connections with electrical tape and pull the new cable with the old cable, starting at the furnace. You will then have all brand new conductors to fit to your new thermostat.
Jan 12, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
