Question about Brother ML-500 Typewriter
Not typing on the paper.
The silver bar does not touch the pin wheel. When you type everything moves along but it does not type.
  • 43 Answers
.See previous answer
Posted on Jun 05, 2014
SOURCE: hammer doesn't strike
Try taking the wheel out and aliging it with the piece in the middle with a hole in it so that the pin and the wheel connect when you push the lever forward to connect the wheel to the disk.
Posted on Sep 14, 2007
JUSTOLDJIM
  • 454 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
  • 86 Answers
SOURCE: My daisy wheel doesn't move when I type and the
no easy fix for this one. take it to a repairman
Posted on Dec 30, 2010
  • 3594 Answers
SOURCE: the wheel on the machine
If you aren't in a language mode or in KBII the printwheel homing pawl is probably broken. You need a tech.
DickyO
Posted on Feb 28, 2011
squipps
  • 204 Answers
SOURCE: Daisy wheel will go to
THE TYPEWRITER SOLENOID IS BROKEN. A TYPEWRITER SHOP CAN FIX THIS IF THEY HAVE THE PART.. SHOULD BE LESS THAN $50
HOPE THI SHELPS, SQUIPPS
Posted on May 06, 2011
The hammer does not move
This problem is the print cam and would require a replacement part you could locate the closes Brother dealer in your area and they should be able to perform the necessary repair. Brother can give you your closest dealer by calling (877) 276-8437.
Apr 14, 2014 | Brother SX-4000 Typewriter
WHEN I TYPE SOME THING AND HIT THE SPACE BAR THE RETURN BAR IT TYPE ON THE SAME LINE AND EVERY THING IS IN ONE .
If the paper will move up with the platen knob the paper feed motor probably has a broken plastic gear. The gear and motor are sold as one 35.00.
DickyO
Mar 15, 2011 | Brother GX-6750 Typewriter
The page keeps scrolling up or down, i have no control over the side scroll at all, i move the mouse over to click on something and the cursor shhoots off in any direction it chooses what it wants as im...
I have been there, I think. The internal mouse in the middle of laptop has a stripe in it along one side. What happens is that your thumb touches it probably, while you are using the keyboard.Look at your hand/thumb the next time this happens.
May 15, 2010 | Computers & Internet
Ipod touch 1st g connection problem
  1. go to your computer
  2. start
  3. run
  4. cmd
  5. ok
  6. enter "ipconfig" with out quote marks
  7. look for where it says default getaway then type that number on the address bar on your internet browser
  8. then, reset your router, recheck the password and name and everything
  9. play around with it you might find something you might like
Apr 25, 2010 | Apple iPod touch
I have a jane powertwin pro and the rear bar that hangs above the clogs for the rear brake constantly rubs on the cogs making a grinding noise with or without kids in it. Please help
This sounds like either your brake bar is loose or has been bent out of shape. Look at the silver metal pins that click into the black cogs (on the inside of the back wheels), if these are not horizontal, then your brake bar has probably suffered some stress, causing the bar to bend and the pins to touch the cogs.
If the metal pins are totally horizontal, then your brake bar is just probably loose and needs removing and re-rivetting on tighter.
Either way, I would suggest that you contact (if in the UK) this link:
www.johnstonprams.co.uk
who will be able to assist with the repair. You can also take this back to the retailer and arrange a repair through them.
I hope this helps.
Sep 29, 2009 | Jane Powertwin - Silver Jogger Stroller
Have the same problem. Wheel does not line up with keys
You have to loosen the screw on each side of the carriage that holds the silver guide and move it away from the font wheel. The factory adjustment is to put in 2 pieces of paper and adjust to be snug. Take out the paper and it should reset properly.
Jul 20, 2009 | Brother GX-6750 Typewriter
Whenever i try to type the type writer types the wrong letters.
The silver guide is touching the fontwheel and keeping it from resetting properly. You need to adjust the guide away from the fontwheel by loosening one screw on each side of the guide and set for 2 pieces of paper on the platen.
Jul 17, 2009 | Brother SX-4000 Typewriter
My cursor on my toshiba laptop keeps jumping when am typing
Ive seen this problem a few times, the problem is that your accidently or inadvertently touching the touch pad as you type. To fix this just disable the touchpad when your typing or put a piece of paper over it. To disable the touchpad it varies on different models but can normaly be done with a button near it, a FN and F1-8 key combo or through the touchpad driver on the task bar. Consult your manual for information on how to disable this.
May 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Hammer doesn't strike
Aug 31, 2007 | Brother SX-4000 Typewriter
Printer ink cartridges move along the bar and then stop
All the HP 500 and 600 series are noisy like this. To help the problem, you would need to open the unit and blow out any dust and paper particles with low pressure compressed air. Put on some latex (medical type) gloves and wipe down and clean all surfaces with a paper towel soaked in 90% isopropyl alcohol (it will be messy). You will have to use multiple paper towels. Check all rollers and insure they will roll. Check the carriage and drive belt for damage. I would also spray a Q tip with WD-40 and swab a light coat on the carriage bar and at the metal edge of rollers (where there are bearings). If this doesn't resolve the banging noise, then there may be a problem with the stepper motor or gearing (plastic gears). This is not normally user serviceable and is not cost effective to repair. You buy a new printer.
Jan 26, 2007 | HP DeskJet 690c InkJet Printer
Brother ML-500 Typewriter Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
