Question about HP LaserJet 4730mfp All-In-One Printer
Paper has paper but doesnt know it
Tray 4 is for our legal sized paper and has legal in it but it does not recognize it. Says paper out. I have replaced the tray and it still doesn't recognize it has paper.
checkitright
  • 1362 Answers
SOURCE: How do I copy a legal size document?
You need to change it in the menu, it's stopping because once it reaches the letter size the sensor detects that there is still paper there and jams.
Posted on Oct 23, 2007
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
  • 15 Answers
SOURCE: Printer insists on printing from tray 1
Go to Printers on start menu, Right-click on the printer go to properties, if you are lucky the 'printing preferences' are on the 'general' tab, click on it and you should have an option there to change it to letter..
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: I have an HP Color LaserJet CM1312nfi MFP printer.
I have the same printer and you have to set the default paper size in the printer itself to legal.
Posted on Oct 19, 2010
SOURCE: My HP laserjet 5p manual feed/ envelope tray
Solved
Posted on Feb 09, 2011
Legal size no print of hp Laser Jet 2420n printer
Hii It could be wrong on this but there should be a setting on the printer for paper size and type for tray 1. Use it to set tray 1 as legal size and then use your program to send to the printer. Another way would be to have no paper on tray 1 and send the job. The display on the printer should say to load legal on tray 1 and hit the button to continue. When you do the printer will now know it has legal paper in tray 1. The last method is only good for that job and will have to be done the same way for another job. Specifying tray 1 as legal paper will allow you to have legal paper in the tray when the job is sent and not have to press the button.
All the Best.....
Dec 11, 2010 | HP LaserJet 2420 Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
Paper Available does not include legal (only letter and A4). Tried to go into the Advanced Properties - no legal available? The printer recognizes the legal tray but the laptop does not.
Try setting the paper size in the printer settings.
Click Printer and Faxes then right click on the HP Laserjet 4350 and click on Properties, then Device Settings tab and click on the down arrow and click on Tray 1 or 2 that has the Letter Paper installed and select the Letter paper size. Then click OK.
This paper tray is now configured for Letter paper.
Jun 09, 2010 | HP LaserJet 4350 Printer
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
HP Laserjet 4 plus printer
use the m/p tray.configure printer to print any size.
Jun 25, 2009 | HP LaserJet 4 plus Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
Tray output
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Panasonic FP-7735 won't recognize paper tray
Can you hear the tray rise when you close it? Is there a red, blinking "out of paper" light on the control panel? Can you select the tray manually?
Or, you had a power outtage, or gremlins, and the settings reset itself, you can go in to service mode and set the trays up again.
Hold the following keys to fire up Function mode. "Function + Original Size + 3". Hit 5 for F5 mode. F5-14 is tray 1. If you have a duplex(ADU) unit installed, you'll want to check out tray 2. F5-14 is tray 1, F5-15 is tray 2 all the way down to F5-18.
Key in whichever number you need.
0: none (no tray installed)
1: Ledger
2: Legal
3: Letter
4: Letter-R (landscape)
5: Invoice
Jan 24, 2008 | Panasonic FP-7735 Black and White Copier
Oct 16, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 4730mfp All-In-One Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
