Question about Wolf Range 30 in. SCB30C Gas Cooktop
The ignitor sparking will not stop in after the
The ignition sparking will not stop after the flame lights no matter which position the control knob is in, except off.
  • 1,305 Answers
Try cleaning your burner tubes. I've been able to solve this by cleaning the burners with a wire brush and cleaning all the holes in the area near the ignitors. You can test with the grilles off. Also adjust the clearance between the burner and ignitors as needed.
You can also do a "cleaning by turning the burners to high and close the lid and let it cook all the "flavor drippings" out of your grill, this should help silience the ignitors too.
K
Posted on Jun 18, 2009
  • 111 Answers
When you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Rings make a clicking noise all the time they are ignited
Turn knob back from "lighting mode" back to normal flame level. If this is not the answer, there may be a control or wiring problem.
The clicking is the normal ignition spark system but usually only operates at the time of turn on until flame is on.
Apr 27, 2015 | Cooktops
No matter which knob I turn on, all 4 ignitors spark,
There is no fix. This is normal. All 4 ignitors will spark but the gas will only go to the burner where the gas is active.
Jun 11, 2014 | Amana AKS3040 Gas Cooktop
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 13, 2011 | Bosch Cooktops
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Wolf Range 30 in. SCB30C Gas Cooktop Logo
906 people viewed this question
Top Wolf Range Cooktops Experts
Michael Galve
Michael Galve
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
