Question about Kodak Office Equipment & Supplies
Can't scan in duplex - Kodak Office Equipment & Supplies
I2400 SCANNER
Posted on Dec 20, 2014
    New Friend:
  • 31 Answers
I can't help you if I don't know what model of scanner you have!!
Posted on Apr 15, 2014
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Tip
ERROR codes Canon 3525
Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Drive
E030 Counter
E030 Counter
E200 Scan problem
E204 Scan
E210 Lens problem
E210 Lens
E220 Lens
E240 DC controller
E500 Sorter
E620 Editor
HP C7280 duplex scan problem
IN XP
click on start and select control panel.
in control panel on the top left hand click on switch to classic view if is not there dont worry.
Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
IN vista
Click on start
in the start search box type "printers" and click on ok.
Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
May 29, 2009 | HP Photosmart C7280 Laser Printer
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Canon DR-2050C - Duplex scanning
Try and reinstall the driver software. IF you had scanned only one page and also had chosen multipage option, the second side will not be visible, unless you use a proper software that can display 2nd side.
S. Mohan
Aug 18, 2008 | Computers & Internet
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Copying duplex documents
Go here for an online document to help you solve this scanning of a duplex document issue.
or type in
http://www.fixya.com/support/p258233-xerox_documate_510_flatbed_scanner/manual-6075
May 01, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
Nov 20, 2007 | Lexmark X4500 MFP Flatbed Scanner
88 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
