Question about Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW
Brother MFC-J6710DW won't print Ledger size prints
My Brother MFC-J6710DW has stopped printing Ledger size pages all of a sudden. All new ink cartridges, all tray settings are correct. Paper selection is correct. Even when I specifically tell it which tray to pull from, it'll print Letter size on Ledger paper (including when I select the 'fit to page' option). I have found no troubleshooting help on this topic.
SOURCE: Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: Brother HL2070N won't print
At the first please check the power & than all connections after that please re-install the driver & go to printer settings & than select the default printer
Posted on Feb 24, 2009
  • 52 Answers
SOURCE: Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
Posted on May 19, 2009
celibytes
  • 70 Answers
SOURCE: My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Posted on Sep 10, 2009
brett207
  • 231 Answers
SOURCE: When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Posted on Dec 09, 2009
Printer no black, already went thru printer's clean printhead and even cleaned print head by running alcohol thru the ink lines
Alcohol is not the way to clean a print head. Simply run the hottest tap water into the ink inlet and print head for several seconds. Since print heads create heat to form the ink droplets needed to form a letter or graphic; running hot water will not DAMAGE the sensitive heads. Alcohol is fine for removing a film (Like fingerprints) from the surface and contacts, but not to be used internally within the head itself.
May as well get a new Black Cart now.
Feb 18, 2018 | The Office Equipment & Supplies
Tip
Brother MFC-J6910DW Review Printer
The professional series MFC-J6910dw will help your company develop with the versatility of duplex printing, copying and also scanning. Make two-sided documents approximately 11 inches x 17 inches house. Easy to arrangement wireless (802.11 b/g/n) or Ethernet network cable televisions with embedded assistance web link to others on the network. 3.3-inch touch screen different colors LCD display menu navigation attributes are interactive and easy to use. Dual paper trays (up to 250 sheets each) supplies an overall capability of 500 sheets. Utilizing Super High Yield (XXL collection) replacement ink cartridge around 2400 web page black and also colour 1200 pages. Neglected tight Fax, copy or scan with up to 35 web page ADF. 3 year minimal guarantee gives peace of mind.
Brother MFC-J6910DW Along with way over the typical paper handling, MFC-J6910DW offers all the standard features of any type of Office supplies, and much more. For a beginning, can print, check, and also Fax over a network and work as a standalone copier, facsimile machine, and also email of the sender. It can likewise check in tabloid dimension, utilizing the automated paper feeder web page 35 (ADF) or flatbed.
Duplex scanning lets you Fax records conveniently duplex, duplex printing as well as mixes while duplex scan additionally allows you duplicate both Simplex (one-sided) as well as duplex record to your liked copy simplex or duplex. Keep in mind, nevertheless, that duplexing for scanning is restricted to an optimal legal size web pages, although the ADF can take care of tabloid dimension web pages to scan Simplex.
The common setup. The printer offers Ethernet and WiFi assistance. For the tests I attached to a wired network and installed it on a Windows View system. Not incredibly, offered the similarity between the printer, MFC-J6910DW the outcomes are basically the very same, documents by file, the MFC-J6710DW, as well as the Bro MFC-J6510DW ($ 250, 4 stars), basically the budget variation of the very same ink-jet printer, with just one paper tray.
I clocked up all 3 printers on our business applications suite (making use of QualityLogic's hardware and software for the time) in 4.1 reliable pages per min (ppm), making them is bound to be a tabloid-capable inkjet asserts the fastest we've checked to this day.
Brother MFC-J6910DW
Amongst the single-function inkjets, editor options Canon Pixma iX7000 Inkjet business Ink-jet printer ($ 399.99 straight, 4 stars) are primarily slower, ppm 1.7. And also between inkjet MFP, HP Officejet options editor formerly 7500A Wide Layout e-all-in-one ($ 299.99 direct, 4 celebrities), can be found in at 3.4 ppm.
The quality of output and also other troubles
Generally, the top quality of the outcome of the MFC-J6910DW equal to or far better than many inkjets across the Board, and also the lid fits MFC-J6710DW MFC-and J6510DW. This text agrees with for a lot of company applications, as long as you do not have an uncommon demand for small fonts, as well as the photo output on picture paper are roughly matched to prints of **** stores, making it greater than adequate for a lot of business requirements.
Different colors in the graphics are slightly dulled down yet also within affordable variety. Right here once again, the quality is conveniently adequate for a lot of business needs, including, as an example, PowerPoint handouts. I see some allure in the default mode, yet it relies on how much of a perfectionist, you can take into consideration a sufficient graphics for outcome will certainly be essential clients or clients.
Dued to the fact that the MFC-J6910DW provides every one of the very same capacities that make MFC J6710DW-editor choices, including the capability to copy, fax, print as well as scan in tabloid dimension, and also print in duplex, extremely easy to suggest. Certainly, if you ever before have to scan a two-sided paper, you're far better off conserving a couple of bucks and purchase a MFC-J6710DW instead. Yet if the duplex Scanning is something that you need or believe you could need, Brother MFC-J6910DW is the apparent option, and also it is still cheap.
All in One Multi Function Brother MFC-J6910DW
on Mar 29, 2016 | Office Equipment & Supplies
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Brother mfc j6710 tabloid print problems
ARE YOU PRINTING THICK PAPER IF YES THEN CHANGE THE PAPER TYPE THICK PAPER
Jun 22, 2017 | Brother "mfc-j6710dw professional series...
Black ink in brother 240c printer does not print new cartridge
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW Logo
Top Brother Computers & Internet Experts
edy copier
edy copier
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
