Question about HP ProLiant MicroServer
Remote access card
Certificate
Certificate error
A "certificate-error" occurs when you access a "secure-HTTP" site (one that uses the 'https://' prefix for the URL) and the "certificate" that the site is "secure" (namely that the site really is the site that it claims to be) is invalid. Certificates have a "start-date" and an "end-date" and certificates can be "revoked". If the certificate is for a different web-site ('web.site.com' versus 'www.site.com') or is revoked, or if the current date is not between the "start" and "end" date, you get the "certificate error" message.
What site did you try to access?
Jan 28, 2014 | Linksys SRW208P 8-Port Ethernet Switch
Tip
How to Hack a S60 phone?
Hacking an S60 phone(V5 and V3) is simple enough. Hacking is mainly done to avoid common problems that symbian users find wile installing cracked applications.<br /> I have listed it in a step by step way which you will find to your liking. <br /> Step 1. First download an application named xstevedore chinese. <a href="http://www.filestube.com/0aac7480d43108c903e9,g/XStevedore-chinese-signed.html">http://www.filestube.com/0aac7480d43108c903e9,g/XStevedore-chinese- signed.html</a> <br /> Step 2. Open up the application and browse to the last item on the screen. <br /> Step 3. It is "setting ". In this the options are : 1. Access point 2. Download path 3. Quit tips Just change access point which u want and i recommend u to change download path to memory card. <br /> Step 4. now go to the second last option Which is "signature ". Then go to options and u will find four options : Choose second one which is " certificate tool" . <br /> Step 5. after that again it will show two options.Choose second one which is "a button to download ". <br /> Step 6.Then downloading will start. <br /> Step 7. then it will ask to save.Then select memory card. <br /> Step 8. then browse to memory card.There u will find a folder named" my cert ". Ur certificates and key files are in the folder. <br /> Step 9 . After that you can use freeshiner or signsis to sign your files with your certificatesStep 4- now go to the second last option Which is "signature ". Then go to options and u will find four options : Choose second one which is " certificate tool" . <br /> Step 5. after that again it will show two options.Choose second one which is "a button to download ". <br /> Step 6. Then downloading will start. <br /> Step 7. then it will ask to save.Then select memory card. <br /> Step 8. then browse to memory card.There u will find a folder named" my cert ". Ur certificates and key files are in the folder. <br /> Step 9 . After that you can use freeshiner or signsis to sign your files with your certificates <br /> Signing softwares can be downloaded from www.mobile9.com
on Jun 29, 2011 | Cell Phones
Sec error expired certificate
This sounds like a "Security Certificate" issue, preventing access to a secured server or website. If that is correct you wil need your security or certificate provider (vendor) to update or re-issue your certificate to allow access to this site. Usually these types of sites are Education, Government, Business-2-Business "Clouds", 3rd Partty Access apps for resellers of IT/Telephony, HR/CRM or financial. A certificate will not be hard to acquire should you have a valid reason.
Hope this helps!
Dec 24, 2013 | Computers & Internet
Need https security certificate for media server/hard drive I&#39;ll explain more now... I have just setup my external hard drive to my router, and I can access it remotely through a browser via a...
You should be able to get around that warning.
Go the the https://IP_Address and install the certificate
For Internet Explorer:
http://support.microsoft.com/kb/931850
or add in an exception for Firefox:
http://oasis.hs-offenburg.de/exception.html
May 27, 2012 | Computers & Internet
Company has a windows remote server 2011. I have windows 7 with ie9. I keep getting certificate errors. I have tried to move it.
this is a clear administrator rights issue you need to resolve with their admin folks. certs are operating system dependent and none of us in fixya have any access to your network server
May 21, 2012 | ASUS Computers & Internet
I cannot open my mail, it keeps saying website is blocked from security certificate errors. Can you help?
Try using thunderbird to remotely access your email thereby skipping the website of the email directly. Your browser seems to be wary of the email site you are trying to access, as it is not correctly giving the appropriate security signature.
Mar 24, 2011 | Computers & Internet
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
How to stop 'allow network access' pop up window in nokia 7610 supernova. Its very annoying that it always comes in between when i am surfing the net.
you download the java software first before you can run: on the phone to find your JAVA applications. Then select the section to stop the application software, press the left soft key operation, go to see the applications access the. Application access - communication - network access, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - communication - data interchange, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - data access - read user data, select Always allow the software without authorization certificate for each inquiry to the election.
application software access - data access - increased selection and editing of data is always permitted, the software did not authorize the certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always prompt " allow network access " this problem, this method is suitable for the Nokia S40 operating system models.
Aug 14, 2010 | Nokia 7610 Supernova Cell Phone
Can not access yahoo mail due to security certificate message
Try checking the date and time of your computer. If is correct, click I UNDERSTAND THE RISKS and add the security certificate.
Hope this helps.
Dec 19, 2009 | Yahoo Mail
Security certificate i cant access it on my phone
If you want to contact Nokia directly, please visit the "Contact Us"-section my 6300 comes with a pre-installed list of such certificates but doesn't include Globalsign. Thesecurity certificate menu
Aug 26, 2009 | LG Shine KE970 Cellular Phone
HP ProLiant MicroServer Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
