Question about Hisense LHDN32V66AUS 32 in. LCD TV
No video No picture with tv, dvd works fine
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
Hi- my 74cm TV- when i connect the dvd player and switch to AV- there is no picture only sound. But the dvd player works perfect on my other TV- what could be the problem??
If your DVD with same AV cord working fine on another TV then its a problem of cold soldering of video pin that needs touch up soldering. And tv work fine again.
Thanks for using fixya.
Nov 06, 2009 | Sansui DTV2760 27" TV
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
No vhs picture.
I HAVE ONE OF THEM TRY HITTING YOUR "TV/VIDEO" BUTTON
Jan 11, 2009 | Panasonic DMR-E75V DVD Player/VCR
Connecting tv to dvd and receiver
in setup you need to select the type of video cable you are using to input
Nov 25, 2008 | Philips Magnavox MWR10D6 DVD Recorder
57H82-no picture from DVD input
How does line out from the DVD player do? I would suspect a bad preamp/buffer on the TV...accordianman
Mar 17, 2008 | Toshiba 57H82 57" Rear Projection...
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Hisense LHDN32V66AUS 32 in. LCD TV Logo
13 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
