Question about Gigabyte GA-K8NF-9 (890552602964) Motherboard
Not booting up.
Hi, I have an A64 3000 venice cpu, 1 gb corsair ram, 6600 gt video card and my power supply blew which was an Apevia AS500W. I bought a new one and replaced it. My computer turns on and everything powers up but the GA-K8NF-9 Mobo does not beep like usual and nothing happens, also keyboard, mouse, cd rom etc does not turn on. Is that a bad motherboard problem?
  • 1 more comment
  • thumper61713 Nov 02, 2007
    No I cannot. Nothing comes up at all.
    No I cannot get into anything. Nothing comes up at all.
    Ok...yes all of the cords are on correctly. The power supply is not exactly the same power supply as the one before it...would that matter? It is the same Wattage and it is powering everything up fine. Its just not booting though. ok...well thanks for your help.
  • 1,601 Answers
Can you get into the bios?
Posted on Nov 02, 2007
  • 2 more comments
  • Thomas Christopher
    Thomas Christopher Nov 02, 2007
    if all of the power supply cords are on securly, it does sound like it may be bad.
    Before you chuck it.
    You may want to try these steps:
    Thomas Christopher Nov 03, 2007
    did ou try this?
    Clear CMOS settings by removing battery
    First locate the battery on the board. The battery is similar in shape and size to a nickel. (Fig 9-a)
    There should be a small clip on the side of the battery socket. Unclip the battery and the battery should pop up and you can to remove the battery
    Remove the battery for several minutes and then re-install the battery. (Fig 9-b)
    Thomas Christopher Nov 06, 2007
    Did this work?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
I have bfg 9800gt it wont boot .. just puts monitor to sleep ... am2 biostar mother 450 watt power supply 3gb ram triple 3.0 amd cpu
ive had a similar problem before. in the BIOS there somewhere, there is an option to make your computer use the ON BOARD VGA, or to use the PCXI. which ever one is selected is the one that the computer will use. if you can change this option in the BIOS, you might be able to use your video card.
Jun 28, 2012 | BFG Technologies GeForce 9800 GT, (1 GB)...
No Display on boot up
When a motherboard does not beep that isnt good news and its either the Motherboard or CPU. Have you fot the FSB settings correct on the board? Is your power Supply Good? Does your graphics card need power and is it plugged in? Unfortunately the only way to findout exactly is at fault is through a process of elimination. Can you try a different power supply first? Also try removing the CPU and re-seating it. If not, then you need to try and get hold of another motherboard and see if everything works in that. If not then it could be the CPU. Diagnosing CPU or MOTHERBOARD is always tricky without spares. Good luck
Aug 30, 2007 | ASUS P5NSLI (0610839134670) Motherboard
2 beeps, no post on my Asrock Extreme3 970
two things:
your RAM's its not fitted right or in right spot.
too small power supply, its to narrow in watts, should have 750 Watts at least.
Mar 22, 2012 | Computers & Internet
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
Hi i just bought an asus m4a88td-m i instaled it with a amd phenom II x4, 500 watts corsair power supply, ati radeon hd 5700 1gb ddr 5 , 6gb ram ddr3 1033mhz and im unable to boot my windows 7 64bits , it...
With all that power, you need a better PSU, the CPU alone draws out 125 watts, the video card can get upwards of 50, RAM takes it down another 25, and that's half of it right there. I would suggest AT MINIMUM a 700 watt PSU. Newegg has em for you (you sound like you can find what you're looking for after all those specs you've given).
I hope this helps!
May 05, 2011 | ASUS Computers & Internet
Computer won't boot.
It is your powersupply, Change the power supply. It should solve the problem. it seems your power supply not giving enough power to the board.
Mar 25, 2009 | ASUS Computers & Internet
New built, no boot
Glad it's fixed. Please remember to rate my answer. Thanks.
Dec 28, 2008 | Intel Motherboard
My computer shuts down when i play or when i exit 3d games
Hi, has the problem recently started after the installation of sp3 because it has been known to cause problems like your having. If the computer is a new build it could be one of two problem, the asrock motherboard which i personally wont use anymore because of constant failure, or your power supply is not powerful enough. i would recommend nothing less than 500w power supply for gaming pc`s.
Hope this helps,
Dec 15, 2008 | Leadtek WINFAST PX6600 GT TDH EX SLI 128MB...
Motherboard problem
Hi Fabio,
Nice system you have.
I would change the timings on your RAM in bios setup pages to a slower set of numbers, especially the last one in the timing from say 12 to 15. If that doesn't help, your cool RAM chips may be slightly defective if you purchased these as a Matched Set from Corsair. And were these RAM Chips in the approved list from Asus for your system board?
Corsair has lifetime warranty for their RAM so getting those replaced shouldn't be a problem.
What you want to do is download and burn a Bart PE bootup CD that has Mem Test 86 on it and run that test on your RAM to verify that the RAM may be defective. Corsair will want to know if you have run a RAM test on those chips.
So, try the slower timing settings, even though you are not overclocking them to start with.
Also, can you put each video card on a separate power rail instead of populating one power rail with both video cards?
Lastly, you stated that you can power off, leave the system off for a half hour and the system will boot. This, as you may know, indicates something is getting hot.This could be your Power Supply or your CPU. Have you used canned air to blow out the power supply and CPU fan and heat sink?
Jul 03, 2008 | ASUS A8N32-SLI Deluxe Motherboard
New Game I Bought
BAD IDEA to post youe email address !!!
May be a video card issue or directX not being at latest version.
What are the specs for you PC?
The min spec to run this game is as follows
OS: Windows® XP, OR Windows Vista™
CPU: Athlon™ 1500+, Pentium® 1.5 GHz, or faster (2200+ or 2.2 GHz for Windows Vista™)
RAM: 512 MB (1 GB for Windows Vista™)
Disc Drive: DVD-ROM
Hard Drive: 8 GB of uncompressed free space
Video: 128 MB video RAM, DirectX® 9.0c-compatible
DirectX® 9 Minimum card: ATI® Radeon® x700 Pro and above
DirectX® 9 Minimum card: NVIDIA® GeForce® 6600 GT and above
Sound: DirectX® 9.0c-compatible
Input: Keyboard and mouse
if your system is not at least at this spec the game probably will not run
Jul 03, 2008 | Video Game Consoles & Games
Gigabyte GA-K8NF-9 (890552602964) Motherboard Logo
202 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
