Question about Norwesco 1000 Gal Plastic Water Storage Tank
15000 litre plastic tank leaking - Norwesco 1000 Gal Plastic Water Storage Tank
Which car is the most fuel-efficient?
1. Maruti Suzuki Ciaz SHVS Mileage - 28.09 kmpl
Tank capacity - 43 L
Range - 1208 km
Engine - Diesel SHVS, 1.3-litre, 90PS, 200 Nm, 5-speed Manual
2. Maruti Suzuki Celerio Mileage - 27.62 kmpl
Tank Capacity - 35 L
Range - 967 km
Engine - DDiS 125 Diesel, 0.8-litre, 47.60PS, 125 Nm, 5-speed Manual
3. Maruti Suzuki Baleno Mileage - 27.39 kmpl
Tank Capacity - 37 L
Range - 1013 km
Engine - 190 DDiS Diesel, 1.3-litre, 75PS, 190 Nm, 5-speed Manual
4. Honda Jazz Mileage - 27.30 kmpl
Tank Capacity - 40 L
Range - 1092 km
Engine - I-DTEC Diesel, 1.5-litre, 100PS, 200 Nm, 6-speed Manual
5. Tata Tiago Mileage - 27.28 kmpl
Range - 955 km
Engine - RevoTorq 3-cylinder Diesel, 1.05-litre, 70PS, 140 Nm, 5-speed Manual
Dec 27, 2017 | Cars & Trucks
My Chrysler 2003 model consumped up one litre of Petrol per one kilometer high fuel consumption. What can be the cause?.
i doubt very much if it would be running at 1 litre per 1 kilometer
at very rich combustion stops at 10:1 as the fuel puts he fire out
I'm not disputing your figures just I would be looking for a fuel leak from a hose , filter leak or leak in the tank or some one stealing fuel
run the fault codes
check the fuel system from tank to manifold
May 10, 2016 | Chrysler Cars & Trucks
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How to compute kilometers per litre
You would fill up the vehicle, then divide the mileage traveled by the amount of fuel it took to fill the tank again.
So assuming you filled the tank each time, you would divide 609km by 100.4 ltr which is .1648 or 16.49 L/100km
Thats about 40 mpg.
Jun 27, 2013 | Cars & Trucks
Engine shuts off when switched to rear gas tank
if it leaks from one tank to another, i deeply suggest you change fuel pressure regulator
Dec 01, 2011 | 1997 Ford F350 Crew Cab
Leaking cooling system
if fan isnt working , water most proberly evaperating when getting hot , try wiring the fan so running constant
Apr 05, 2010 | Peugeot 405 Cars & Trucks
4.3 vortec in 93 blazer getting 85km's per TANK and had 3-4 litres of fuel in the oil pan,no fuel leaking onto the ground?WHY???
go to a mechanic the reasons for this are too complicated to explain here ,anything from a injector to a hole in a piston.
Jan 18, 2010 | 1993 Chevrolet S-10
Running out of fuel
you may have a transfer hose in the tank leaking. sometimes from fuel filter sock in bottom of tank to fuel pump in tank, the hose slits. not sure on nissan though.
drop tank and remove pump and examine pump & lines.
Dec 12, 2009 | 1990 Nissan Minivan
Fuel leak
Check the flexible tube between the tank and the filler cap and the outlet hose from the tank. It's probably a slow drip which means it's leaking all the time though.
Oct 03, 2009 | 1994 Land Rover Defender
Norwesco 1000 Gal Plastic Water Storage Tank Logo
71 people viewed this question
Top Norwesco Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Norwesco Plumbing Expert? Answer questions, earn points and help others
