Question about Toyota Computers & Internet
Cuts out on high revs - Toyota Computers & Internet
2001 grand prix when you rev up motor in park starts cutting out at high rpms
IT IS DOING WHAT ITS SUPPOSED TO DO. THE REV LIMITER IS TO KEEP YOU FROM HAVING HIGH RPM WITH NO LOAD ON ENGINE
Dec 23, 2014 | Cars & Trucks
Whats the cause of high revs after cleanin the engine when starting it
you obviously have gotten water in somewhere not meant to get wet. if it hasn't fried anything it should settle down as it dries out.
Jul 14, 2012 | Cars & Trucks
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
Jul 03, 2012 | Stihl Garden
I have a Poulan (18"
IN SOME MODELS THERE IS 2 SCREWS NEAR THE CARB.THE SMALL ONE IS FOR LOW REVS AND THE BIGGER IS FOR HIGH.START THE MACHINE AND PLAY AROUND WITH THE SMALL ONE UNTIL YOU GET THE RIGHT LOW REVS,LEAVE THE HIGH AS IT.
I ALSO SUGGEST TO DO A TUNE UP.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have 1999 cavilleir does it have a rpm protecter
Yes, the PCM for your vehicle's engine has a rev/speed limit seeting programmed into it. Most stock, non high performance/police package vehicles usually won't go above a top speed of 97MPH. if you were to rev your engine while it was in park or neutral, once the engine reaches the cut out rpm limit preset in the PCM, it will cause the engine to cut back, then it will rev up until it hits the preset limit, then cut back, and it keep repeating that pattern. It may sound as though you have a high rev ignition failure that sounds like waaa, waaa, waaa, waaa, but that indicates the PCM is doing its job.
Apr 05, 2010 | 1999 Chevrolet Cavalier
Idle high then cut off
Most likely need the idle readjusted. Your vehicle has a high idle rev limiter that will shut down the motor to keep it from getting damaged. Make sure your accelerator line isn't being pulled on. This will pull on the gas pedal just like having a foot on it and will rev the motor as well.
Mar 28, 2010 | 2004 Dodge Durango
Cuts out on high revs 240 chain saw
Many saws made today are using electronics for engine control. If the engine rpm's starts to rev to high, the electronics in the coil will start to 'cut out' some of the spark. This is normal in this senerio.
But, now the real problem causing the senerio;
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 10, 2009 | Husqvarna Chain Saw 20" Bar
Engine cuts out
Maybe when you went into the ditch you partially pinched your fuel line so now your not getting enough fuel to the motor?Crawl up under your car and see if you can see any damage to the fuel lines, or anything else...filter etc.
Oct 02, 2008 | 1997 Nissan Sentra
Computers & Internet Logo
11 people viewed this question
Top Toyota Computers & Internet Experts
David Payne
David Payne
Are you a Toyota Computer and Internet Expert? Answer questions, earn points and help others
