Question about Huawei M886 Mercury - 4GB - Black Cricket Smartphone
Bauhn tablet touch screen does not respond to anything
Bauhn screen does not respond to anything, i tried re set and still does not respond to anything.
My Bauhn Keyboard case for iPad Mini has the American keyboard overlay but is set to German. Y key types Z, semi colon key types o with Umlaut etc. How can I change the language.
Language must be in Settings on the ipad unless it has an app. I looked for instructions, but there are non online apart from for a Windows Keyboard. It does however have contact details.
PDF]10.1" Windows Tablet Keyboard and Case - Bauhn www.bauhn.com.au/_literature_141875/AKCD-215_-_Instruction_Manual
  1. Cached
  2. Similar
INSTRUCTION MANUAL. 10.1" Windows Tablet Keyboard and Case. Suitable for the 10.1" Bauhn Sphere Windows Tablet. 1300 886 649. Model: AKCD-215 ...
Dec 04, 2016 | Mini Computers & Internet
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
My tablet 7.85 touch screen not responding.cant switch on or off or reboot.Only 5 days old.
It is not the normal behaviour of a new tablet. Don't mess with it. Your tablet is on warranty. Look up where you should take it for a checkup and repair service
Feb 06, 2015 | Tablets & eReaders
MID model M729B can not get the tablet to respond to unlocking the screen
Here's a link to the manual:
http://www.mymidpad.com/M729B_User%20Manual.pdf
You need to do a hard reset which will wipe all data and restore the tablet to factory settings.
Jan 18, 2015 | Tablets & eReaders
How to do firmware reset on a bauhn tablet - model AT - HK8
OK THIS WORKS 100%
1.Use a pin in the rear reset hole whilst holding the power button for A-HK8 Aldi Tablets, hold until the screen flashes white once, Then turn on Power as normal....it will appear to be stuck on the ANDROID logo but it isn't....
2.wait with the android logo showing on the screen for 3 minutes, don't touch anything, just let it be for 3 minutes....
3.the upgrade or optimize app menu screen will come on, let it finish the upgrade usually 1 or 21 ..(let it do it if this comes up don't touch anything) ...if no upgrade is required, it will go straight into the screen ready mode with the clock.....
4.navigate into settings, and select backup and reset......(at this point if you have a SD card i would backup your apps and google account to it) otherwise hit erase everything.....and factory reset the
tabletTechnicians notes:
I must also say that the dual core in these HK8's get very overloaded and overheat when playing it, as there is no gills or vents on the back cover, this is a manufacture fault by Bauhn, and they have since stopped making these,
it's a shame as it will only last a short while maybe 3 months or more until you need to do a hard reset all over again, as the tablet overheats mid use and causes a corrupt shutdown and when turned on again will need another dammed hard reset.....they constantly need hard resets... if you haven't the heart to throw it in the garbage and say goodbye to your $200 then ...this is what you will have to prepare for if you continue to own it..
one good thing though, is anything you backed up like apps, google play accounts, and photos can easily be used on a new tablet say like a "samsung" if you keep getting the crash error saying " Apparently such and such stopped working" means the Core duo chip is overheating at this stage, feel the back cover its unaturally hot and your battery juice is being sucked dry. means pretty much your core duo is fried and anything you touch will stopp working, it can't run when that hot....like i said earlier this is a common fault with the AT-HK8 Tablets from ALDi...and why Bauhn quickly stopped manufacturing them and offering support any longer....believe me after hard resetting it a few times every few months, you will want to take a hammer to it or frisbee it against a wall. up to you.
Feb 15, 2014 | Tablets & eReaders
The home screen is blank
well possibly just a backlight issue. but is it worth even fixing ???
Dec 31, 2013 | Computers & Internet
Tablet reset
Hi, If you are in your tablet, touch "settings" they should show up on the left side of your screen. Scroll down until you see "Reset to Default tap that and it will take you to another screen asking you if you really want to do that, make your selection and Zeki will automatically do it's thing and erase everything, shutdown and power up again. This should be the same for all Zeki Tablets.
Jun 10, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Huawei M886 Mercury - 4GB - Black Cricket Smartphone Logo
24 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
