Question about Cuisinart DCC-1200 Coffee Maker
Clear water leak - Cuisinart DCC-1200 Coffee Maker
Leaking clear fluid passenger side front. Car made strange gear like noises before failing to run anymore and the leak at same time occured
Clear fluid leaking on that side suggests it is drainage from the air conditioner. None of the fluids in a car are normally clear.
UNLESS you have a serious antifreeze leak and you have topped it off with clear water.
The strange noise is most likely not related to the water leak unless you have used clear water in the cooling system.
It is too hard to diagnose that noise over the internet. It will need to be examined by someone who has good knowledge of cars.
Good luck with this. Those Neons are usually not too difficult to work on and and treated right, they can run for many years.
Sep 14, 2015 | 1999 Dodge Neon
Tip
F/Freezer Water leaks
Most times water leaking from a F/Freezer is due to a blocked drain hole....This can be cleared simply by using a plastic straw..put a little water in your mouth then using the straw direct this down the hole to clear and flush out at the same time.....Dont use any metal or solid to clear as it may damage..
on Apr 06, 2010 | Refrigerators
1983 buick regal water leakage
Is it clear water or coolant ?
Clear water could come from the a/c or a drain for the cowl or roof.
Aug 02, 2012 | 1983 Buick Regal
My 2003 dodge grand caravan is leaking water from a line about under the passenger side. Radiator is low. I can see water leaking.
that water could be the condensation line,, if you have had your AC on, water will leak from along the firewall on the passenger side, where the tube runs out of the vehicle. Your radiator could have been low to begin with and when you saw the water leak,, you though that was it. check the puddle,, is it clear water or does it have antifreeze in it? If its clear water chances are , that its just the drip line from your AC, if it does contain antifreeze , check the 2 water hoses that run into the heater core , you can also see where they go into the cab portion of the van, from under the hood,
Sep 17, 2011 | 2003 Dodge Caravan
I have 1998 cadillac seville. Added coolant, but air-conditioner didnt come on. Cleared ACM code and air came on. Next day hot water was leaking on foot pedal while I was driving!
hi is water or coolant that is leaking .if its coolant leaking your heater core
needs to be replaced .put if its water leaking all you have is clogged water
drain . to fix open hood on the passenger side fire wall is a small "L" shaped hose
that comes out of the fire wall and not connected too anything clear hose
BEFORE PUTTING HANDS BY FIRE WALL &ENGINE MAKE SHORE
ENGINE IS OFF AND COLD . IF NOT YOU CAN GET INJURED
Jun 13, 2011 | Cadillac Seville Cars & Trucks
Water leaking into the floorboard.
Check to see if the water drain for the A/C system is plugged.
Look under the vehicle for a drain tube just ahead of the passengers feet.
Try to clear it.
Watch out for a flow of water if you do clear it!
Do not push higher into the drain than is needed to clear it.
If the heater core was leaking you would have antifreeze on the floor....not water.
Yes,the coolant would go down if the heater core was leaking.
Aug 26, 2009 | 2000 Dodge Caravan
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
My 1997 grand prix gtp has a leak
Is it water or coolant that leaks inside. Water will be clear, coolant will be yellowish-green or blue. If it is clear than it is just a rubber hose that is loose from the AC drain. Replace the hose and clamp. If it is coolant then you have a leaking heater core and would need to get it replaced.
May 12, 2009 | 1997 Pontiac Grand Prix
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Clear Oil leak on Mitsi Mirage 1989
could the clear oil actually be water?. if it is leaking out in the area around or behind the passenger side front wheel on hot days, it is probably water from your A/C, system. it has an overflow or drainage pipe, as the process of cooling the air dehumidifies it and produces water. just a guess though
Jun 21, 2008 | 1989 Mitsubishi Mirage
Cuisinart DCC-1200 Coffee Maker Logo
13 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
