Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Deep cycle batteries won't charge - Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
How do I know what battery to buy and how do I hook it up to my gulfstream coach
Above all, buy the best battery you can afford. You can't have too much battery! A standard sealed lead-acid battery is okay for the engine, but I would suggest an AGM battery for the coach. AGMs are longer lasting, charge quicker and can stand abuse. Make sure it is a deep cycle battery for a RV, NOT A MARINE TYPE DEEP CYCLE. Marine type deep-cycle batteries are designed to start engines along with their deep-cycle capabilities. They WILL NOT last in an RV.
Make sure the replacement is the same design i.e. + post on left (or whichever). Compare to original battery. Switch breaker off for coach. Replace battery. Hook up the RED cable to + FIRST, then black cable to ground. Switch power back on. You can charge it if you want to, but I never noticed any need.
Sep 29, 2014 | RVs
Is century PS12120L deep cycle? Can it be fully discharged frequently?
all the jump starts i have seen have a deep cycle battery that is sealed - i would not run something like an air compressor motor with low voltage - it can be discharged almost flat , but do not leave it long before charging back up - low voltage =high amps on motors
Jul 19, 2014 | Energizer All-in-One 12V Jumpstarter Air...
Can I over charge my mobility scooter batteries with a pihsiang charger the green light wont go solid
Take the batteries to a battery shop or a Battery plus store have them load test the batteries. Deep cycle batteries are different from normal batteries. Normal batteries are design for max output for short periods of time, Deep cycle batteries are designed for a modest output for long periods of time. My batteries are rated at 35 amp/hr.. Basically a load tester places a load in amps [cranking amps] on the battery. How many cranking amps depends on if there is a voltage drop when you apply the load. I can apply 480 cranking amps before my voltage drops. What i do is load test a new battery of the same type to find out the cranking amps. You will not find a cranking amp rating for aq deep cycle battery but retail places have load testers that read in cranking amps. Use only deep cycle batteries in scooters, garden tracker batteries will not last. If the batteries are ok test the charger. A CHARGER KNOWS THE CHARGE OF THE BATTERY BY BATTERY RESISTANCE. As a battery charges its resistance get bigger. Once the battery reaches a preset resistance the light goes solid. You can have the charger checked by a battery shop. To properly charge a battery a charger will put out 27volts @ 4amps, they can easily test for voltage. Now if the charger is built in there is going to be an external fuse find it, check it. hope this helps
Jun 07, 2012 | Health & Beauty
General inverter question. Running off of a car battery do I keep the car running or just juice the battery every now and then to keep the battery from dying:
Automotive batteries are designed for a quick draw of amperage (when starting) and then get constantly recharged using the alternator when driving. If you are using an auto battery for inversion, it will drain much quicker. Depending on how/where you are using it, you could charge the battery when a meter shows a voltage drop. Better recommendation would be to use a marine battery, which is a deep cycle battery. Deep cycle batteries last much longer between charges, as they are designed to have a constant draw (trolling motors, etc.).
Aug 27, 2011 | Garden
Just purchased 1985 pace motor home it has one deep cycle battery and one regular side post battery. I charged the deep cycle and the motor barely turns over, wondering if I am supposed to have two deep...
Hi, the deep cycle battery is for the home part and should charge through the external connector port. The regular battery is for the engine. Is the regular battery charged up too?
Jan 01, 2011 | Chrysler E-Class Cars & Trucks
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
Cant start the tractor. Turn the key and nothing happens
More than likely the battery is dead. You can go out and buy a new one or you can go and buy a trickle or deep cycle charger. Both are good for putting a nice deep charge back into the battery. Also try checking the water level in the battery before charging it. Yes the charging road will take several hours to a day or so depending how dead the battery is. Good luck.
May 10, 2009 | Garden
Tech Question
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Aug 27, 2008 | Whistler Power Inverter
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
