Question about LG Art Cool LA091HNP Split System Air Conditioner
Error code ch 45 - LG Art Cool LA091HNP Split System Air Conditioner
What does error code CH 24 mean?
The CH67 code is generally related to either a fan motor failure or a blockage to the air inflow. It is recommended to check the filter, and make sure that none of the vents are obstructed. If this does not resolve the matter, then the unit may require service. To make service arrangements, you may either contact our Customer Interactive Center at call_skype_logo.png800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair....
Sep 01, 2014 | LG Electronics LD451EGL 45-Pint...
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Error code ch
CH mean any kinds of door is open or not close properly.Please close door properly.right side or front side.it has a connector switch it is open or displace.
Dec 15, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Error code on Digital LG Dehumidifier - CH 1
Change the sensor assembly, Part # 6877A30013M from Appliance Factory Parts in Englewood CO, about $30. Easy to change, plugs into control board, remove old temperature probe by pry T-well open with small screwdriver and then crimping back closed when new sensor is installed, about an hour start to finish, hardest part is getting all the covers off. Mine is back to working like new again!!
Nov 10, 2008 | LG DH404E Dehumidifier
Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Jul 24, 2008 | Sharp SF 2020 Copier
LG Art Cool LA091HNP Split System Air Conditioner Logo
24 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
