Question about Polaroid PoGo Digital Photo Printer
Error (-21860) file transfer failed error (-218600 HAS OCCURRED
Pogo printer error -21860
Don't name files with characters like - . & or something like that.Hope that the tip will be useful.
Jun 04, 2012 | Polaroid POGO Office Equipment & Supplies
Pogo polaroid
Don't name files with characters like - . , & or something like that.
Apr 13, 2012 | Polaroid PoGo Digital Photo Printer
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
Lost the maps
Depending on how much data needs to be transferred it may pay too get a 2gb or larger SD card as some of these maps are quite large
Jul 10, 2010 | Tomtom ONE GPS Receiver
File error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
May 30, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Error An error occurred while loading the COM file
uninstalled the program, downloaded the latest trial version from Sony (25 da trial) and recovered the files without errors. I will try to repair my own version later.
Thanks for your reply.
Dec 19, 2009 | Sony Vegas Pro 8 for PC (SVDVD8006)
Hi, my ps3 wont read bluray discs. I was getting an 800 series error code on the disc startup but now it won't even see the discs. It does see ps1 and ps2 discs, as well as cd's and dvd's. I ordered an...
Hello sir
Here The 800 Series Error Codes :
80029945 - Can’t playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete
some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3
processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading
game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added
27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted
folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during
disc swap tests)
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Polaroid PoGo Digital Photo Printer Logo
67 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Andrew Taylor
Andrew Taylor
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
