Question about Maytag 30" Self-Cleaning Freestanding Gas Range - White
Dr error on kenmore oven - Maytag 30" Self-Cleaning Freestanding Gas Range - White
Dr is displayed and will clear. oven or cooktop notworking
Error code DR can refer to a door lock malfunction. Try resetting by turning off the power to the oven for at least 5 minutes. Power back up, if the error code continues you may have a faulty door latch, or light switch, or in worst case Electronic control unit.
Dec 05, 2014 | Kitchen Ranges
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Beeping sound with a message dr
I have a kenmore elite range model#790.9802. the walls of the oven expanded after a self cleaning cycle that the rake fall. i want to take the oven cavity out and reshape it. the problem / anyone know how the oven cavity comes out? I don't want to break the oven by trying to remove it the wrong way.
Sep 23, 2013 | Kenmore 75844 / 75849 Gas Kitchen Range
I have a Kenmore gas range 790.7744, 7745, 7746,7747,7748 and the sensor for the oven temperature show a dr. Can you please tell me what is wrong with it?
I am sorry you are having a problem with your range. The DR code indicates that you have a problem with the door latch assembly. The latch may not have fully retracted when unlocking the oven door or you could have a switch or wiring failure on that mechanism. A failed control board could also cause this problem.
Unplug the unit for thirty mins. and plug it back in then post the results back to me.
Aug 31, 2013 | Kenmore Kitchen Ranges
Range elec #fef352awf oven will not work digidal code comes up Dr?
Hello Mike, an error code DR commonly refers to a door lock malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit on. Typically, this will clear most false error codes. If the error code continues to display, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements. I hope this information proves to be helpful.
Aug 03, 2013 | Frigidaire Ovens
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I'm getting an error mssg "dr" displayed on my kenmore dryer model 84082. help!
"DR" is not a known error - please re-check and post the error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Kenmore 67082 Electric Dryer
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Maytag 30" Self-Cleaning Freestanding Gas Range - White Logo
37 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
