Question about Ovens
Lam2502 filter change
How do I install charcoal filters How do I install charcoal filters
Fridge inline water filter
I assume you have an external filter, and you want to replace it? I'd buy an exact replacement and it should have instructions. All filter's seem to have different connection methods. If you don't want to replace, you can cut the tubing and connect the tube with a splice or compression or similar type of "splice" Talk to your friendly hardware source.
Oct 09, 2015 | GE JRP28SKSS 24" Double Electric Wall Oven...
How to change the light bulb in a maytag 8114P732-60 oven
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm.
Good luck
Jul 27, 2014 | Maytag CWG3100A Gas Single Oven
I need to change the sponge filter but cannot seem to buy one
go to the place u bought the unit. if that does not exist, then git 2 homie depot,lowes, or sears,who ever. and take u r filter with you. there r replacement filters, or alternatives. lol.
Apr 13, 2014 | Baumatic Ovens
Find artifact images
In cooking a dutch oven is the original slow cooker. Usually made from cast iron, and can be used on top of a wood burning stove, in a wood burning fireplace, over a campfire, or with coal/charcoal. Some have domed lids, while others have a flat lid with a raised edge (aka flagged lid) which is idea for holding charcoal above the kettle. This allows for heat both above and below the dutch oven. These are generally available in stores such as Cabela's, BassPro and others.
Dec 02, 2013 | Ovens
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
I have a May Tag dishwasher and I am very unhappy. I use Jet Dry and a small amount of Cascade and my glasses get a white film on them. They look terrible. What can I do? Susan Ferrin
Perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 13, 2011 | GE Built-In Dishwashera Oven
Sfe comes up when autofry is turned on
The SFE is a code that stands for safety. Typically this happens when one of the push buttons is not pushed in all the way. Check the buttons inside the filters area, make sure the filter cover is on correctly and make sure the door is closed when turning the machine on. If you contine to have problems, please contact MTI manufacturers of the AUTOFRY @ 1-800-348-2976.
Sep 26, 2010 | Ovens
There is a small light blinking on the refrigerator side. bottom right part of what would be a digital 8 disply
need to know brand and model # // it could be a the filter light / and you need to change filter .. ..
Dec 02, 2009 | Ovens
Is there a filter on the model KSBS20QEBL0? The ice has a terrible smell - have cleaned with baking soda, with no results.
i stinky piece of fish or any thing stinky in the frig side will smell up the Ice. Dump all ice wash out the bin with bleach and water.
Some frig's have a filter , some do not.
Nov 21, 2009 | Ovens
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
