Question about Dell Studio Xps 7100 PC Desktop
Overheating "studio xps 7100"
After being off over night, the system will start normally and remain stable for about 15-20 minutes, but then randomly shuts down, show screen tearing, freezes, or restarts. After this happens it will not complete a restart successfully. I have reseated the memory cards, and checked all connections for tightness, and cleaned all possible dust from the inside of the machine. With the panel open, I have briefly started the machine and witnessed that both fans are operating.
  • Dell Master
  • 15,691 Answers
Download this: http://almico.com/speedfan451.exe
It will tell you what is overheating. It may be the heatsink grease on the processor is dried out and not conducting heat away like it is supposed to.
Posted on Sep 16, 2015
PcExpert
  • 293 Answers
SOURCE: Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Posted on Sep 16, 2007
ComputerGirl
  • 85 Answers
SOURCE: vertical lines, screen freezes, laptop shuts down
it most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
Posted on Jan 24, 2009
SOURCE: Dell Dimension 5150 starts up on its own!!
Hi All,
I had the same problem - shutting and restarting over and over again. When called Dell, they said it is most likely the motherboard and will need changing. I personally suspected that it has something to do with the power supply.
I was right. I replaced the 305W power supply with a 370W one. Problem solved with just £25 and a trip to Maplin.
Let me know if this helps.
SOURCE: XP Keeps rebooting with LAN Cable connected
hi banchimuthu ,
this restart problem is spyware problem,you can solve this problem by combofix& sdfix
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: Dell Inspiron 531 keeps shutting itself off.
if it's overheating, then u should try to put it in a cooler place. : )
Posted on May 15, 2010
Dell studio XPS 7100 tower. the power light is orange and it wont start
The amber light can mean that the power supply isn't providing enough power to the system board or that the system board (or the CPU on the board) isn't working.
Since your fans are working, your power supply hasn't completely failed and the board is providing power to the system fans. Thus, either the power supply is giving limited power, your CPU has failed or the motherboard isn't talking to the CPU anymore. (The BIOS is only accessible when the CPU is operational.) I'd first try a new power supply. Make sure to get one that has at least the same power rating as the original, matches the wiring in your case and will fit in your case. (Note: you need to be careful. 1) Some Dell systems use a proprietary power supply (shape and wiring). 2) Many current power supplies are rated by their peak power output, not their stable power output. You want to match or exceed the stable power output of the current power supply.)
If the power supply doesn't solve the problem, I suggest getting a new computer is better than a new CPU or motherboard. (The Dell Studio XPS 7100 was released in 2010.) Replacing the CPU or the motherboard makes your computer a new machine to Microsoft and you may have trouble getting a working license. (You'd have to call Microsoft for activation and they probably will want to charge you for a new license.) Take your hard drive out of the current machine to get your data from it. You can put the drive inside another desktop with SATA ports, use an external drive enclosure (3.5") or SATA drive dock, or a USB to SATA drive adapter.
I hope this helps.
Dec 28, 2013 | Dell Studio Xps 7100 Desktop Computer (AMD...
My flopy drive will not read any disc I pu in it.
Floppy on an XPS? Is the drive an external one? What operating system?
Oct 14, 2013 | Dell Studio Xps 7100 PC Desktop
Solid orange light
First check that when u power ON the desktop then light is coming on ur keybaord. And after five minutes again check this.
Sep 01, 2013 | Dell Studio Xps 7100 PC Desktop
My Dell Studio XPS 7100 Desktop Computer has suddenly developed a whirring sound. What could cause this?
That is a fan causing the problem. First thing to do is open the side panel and clean out the dust, sometimes that helps. Next, with the side panel open, turn on the computer and look to see which fan is causing the noise, they are easy to replace. If it is the CPU fan it may be a more involved repair but its usually not too bad.
Dec 18, 2012 | Dell Studio Xps 7100 PC Desktop
Windows 7 starts slow
win 7 is slow. its also a memory hog. you should have at least 4 gigs of ram. This is only one of many things that will make the computer start slow.
Aug 19, 2012 | Dell Studio Xps 7100 PC Desktop
Windows 7 takes 30 to 40 secs to boot
Bootmgr file is corrupted, repair or reinstall the Operating system window 7
I have a dell xps studio 7100 with a 500gb hdd. I want to buy a 2tb and make a secondary drive for storage on my media center. How do i install a second hdd for storing my video files and music?
installing the secondary harddisk may cause to slow the system as to install first change up the ram and then partations of hard disk may be done while formatting so u can store what ever accessarioes u need
Dec 13, 2010 | Dell Studio Xps 7100 PC Desktop
Dell Studio Xps 7100 PC Desktop Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
