Question about Samsung Ultra SlimFit 20" Digital TV
17 inch flat monitor not disply only fliker - Samsung Ultra SlimFit 20" Digital TV
Do any of your dell 17 inch monitors have built in speakers?
17" Dell monitors don't have speakers, as a matter of fact, I haven't seen any Dell monitors with speakers.
Feb 19, 2014 | Dell E173FP 17" LCD Flat Panel Monitor
Auto adjustment locked and picture is fliker
Its not auto adjusting because of the flickering. Its flickering because the screen itself is losing voltage so it cant stay on. You can try hooking up the monitor to another computer just to rule out a bad video card but it looks like replacing the LCD is the only solution.
May 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Just monitor power on disply comes but after some seconds disply is gone
On Samsung 740 this is a very common problem with the high voltage impulse transformator in the invertor block. That needs to change.
May 16, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
On off button monitor is broken
HI
if you getting disply it mean u have problem with penal only just replace you penal body
May 25, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Pavilion F1703 17" LCD Monitor: my moniter lose disply but sound is there it happe...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP Pavilion F1703 17" LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
My Westinghouse monitor fliker for 1 sec and dont diaplay anythin
Make sure all cables are tight if that doesn't work you need to put it in the shop if its still under warranty if not you need a new one
Mar 10, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Samsung Ultra SlimFit 20" Digital TV Logo
12 people viewed this question
Henry  Thomas
Henry Thomas
