Question about Oreck Air Purifiers
Oreck air electronic air cleaner motor - Oreck Air Purifiers
Replacement motor
Did you check out ebay? Google it.
Mar 02, 2016 | Oreck XL Professional Air Purifier
Need a wiring diagram for Oreck XL air purifier Air8SD
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
Aug 04, 2014 | Oreck Air Purifiers
My oreck magnesium keeps turning off. Blue. Light keeps blinking
THE PROBLEM SEAMS TO BE WITH THE THICKNESS OF THE CARPET AND THE PAD-ALL VACUUMS NEED TO BE ABLE TO BREATHE IF THE PAD AND THE CARPET ARE THICK THE VACUUM WILL PULL ITSELF TOWARD THE FLOOR SLOW DOWN THE BRUSHROLL ENOUGH TO TRIGGER THE AUTO SHUTDOWN ON THE MAGNESIUM BECAUSE THE VACUUM CANT BREATHE. TAKE IT TO YOUR LOCAL ORECK AND THEY CAN PUT A FEW HOLES IN YOUR SOLEPLATE AND THIS WILL TAKE CARE OF THE ISSUE.
Apr 02, 2013 | Oreck Magnesium Upright Vacuum Cleaner
My oreck air purifier xl won't turn on
With the Air 8 Models there is a number of issues from the motor to the power supply to the circuit boards. With these old units it is hard to find parts for them. as oreck no longer manufactures them. but if the parts were availible i would estimate around 100 to fix your power issue
Sep 15, 2011 | Oreck XL Professional Air Purifier
I need instruction on how to clean my Oreck XL.
Unplug the unit before cleaning. Wipe off the cabinet with a soft cloth and a mild non-abrasive cleanser.
To clean the electronic collector, loosen the front grill retainer screw then press in the lock and remove the grill. Pull out the collector by the tabs on the sides using both hands. Snap off the charcoal filter from the back of the collector. Then slide off the pre-filter. Spray the pre-filter and the collector with the Oreck Assail-a-Cell cleanser and then let stand for a few minutes before rinsing with water. Otherwise, soak the pre-filter and the collector in warm water (bathtub or sink) with mild dish detergent. Soak for 2-3 hours. Rinse well.
Then allow the parts to dry for completely before reassembling the air purifier. Air dry only.
Pictures to go with the Oreck XL Professional Air Purifier cleaning directions are in the manual. It is available here: http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf . See page 5.
I hope this helps.
Jul 06, 2011 | Oreck XL Professional Air Purifier
Owners manual for the Model#8sd wold be great!!
I have a Oreck XL Type 3 Model Air 8 SD....needing the rubber fitting
between the motor and fan blade....can you help?
Jan 16, 2011 | Oreck XL Professional Air Purifier
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
Nov 12, 2008 | Oreck (AIRCOM1WOI) Air Purifier
Cleaning the grid
You clean the cell by soaking it in warm soapy water in the kitchen sink: "
soak the Electronic Collector Cell in warm
water in a kitchen sink or bathtub. Mild dish detergent (powder
or liquid) may be added to the water to help break down the
dirt on the Collector Cell. The Collector Cell should be allowed
to soak for two to three hours."
See the instructions here:
http://www.oreck.com/customer-service/owners-guides.cfm#
Dec 29, 2007 | Oreck Super Air 7 Air Purifier
Air Purifiers Logo
52 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
