Question about HP DeskJet 895cxi InkJet Printer
Its not pulling - HP DeskJet 895cxi InkJet Printer
Yard machine Y25-line spindle does not turn when pull cord is pulled
When you say it doesn't 'turn' when you pull the pull chord, do you mean the engine wont pull over or is hard to pull over.?? Possibly partially seized. Remove the exhaust and check the piston isn't scored..
Apr 19, 2016 | Garden
Will only pull in 4th gear and in 4 wheel drive
Automatic, or Standard? Last time transmission serviced? If auto, check fluid, if smells burnt, get serviced. However,it sounds like a problem in the linkage/s from the shift lever to the transmission and 4wheel controls.
Jun 14, 2015 | 1992 Geo Tracker
My Homelight 26b MightyLite leaf blower is so hard to pull start I have to put my foot on it to steady it. I pulled the spark plug and now it pulls so easily I can pull the start just holding the uni
Joe,
Compression is what makes it hard to pull start.
It should be like that.
Try holding the Draw/Pull Cord tight to your stomach and push the Blower away from you.
Kind of like throwing the blower down & away, but holding on to it.
That might be easier than pulling the cord and will save your arm.
Good luck !
Dec 06, 2014 | Garden
How to install flywheel ford f150 6 cylinder engine
Pull drive shaft 4 bolts next pull transmission cross member 4 bolts pull transmission lines 2 pull all wiring 2 pull transmission inspection cover 4 bolts pull transmission 6 bolts pull flywheel 6 bolts install new and reverse process
Aug 12, 2014 | 2005 Ford F-150 SuperCab
Pull cord only pulls out 4 inches at a time, but will eventually pull all the way - how to get it to pull out all at once?
TRY OPENING COVER,REWIND BY HAND,WITH THE COVER OFF SLOWLY PULL CORD OUT,WATCH AND SEE IF THE PULL CORD GETS HUNG UP.THAT MIGHT BE THE PROBLEM,
IF THE CORD COMES OUT WITH NO PROBLEM,THEN THE CORD IS NOT CLEARING THE CORD COVER,JUST LINE IT UP ANS TIGHTEN SCREWS,GOOD LUCK,
Aug 10, 2012 | Stihl Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
I pull the latch inside the car to open the hood of my 2000 vw passat and nothing happens, i pull up on the hood still wont give
either the hood cable is strecthed and not pulling the cable far enuff,or the cable is seized or the latch is broken,try pulling the actual cable and not the lever,,,with like a pleirs or something
Oct 16, 2009 | 2000 Volkswagen Passat 4Motion
Cannot pull the pull rope. Feels like motor is froze but when I pull the pull rope cover off the pull rope pulls freely and I can turn the fly wheel by hand easily. Put everthing back togeather it will not...
PISTON COULD BE SEIZED DUE TO LOW OR NO OIL MIXTURE,ALSO IT COULD HAVE FUEL IN THE CHAMBER,FIRST REMOVE SPARK PLUG--NOW TRY TO PULL IT--HINT,STICK A SMALL SCREWDRIVER IN THE HOLE AND SEE IF THE PISTON RAISES AND LOWERS,,IF IT WILL RAISE/LOWER BY MANUALLY TURNING THE CRANKSHAFT,THEN THE PROBLEM IS IN YOUR INNER PULL ROPE ASSY.(THERE ARE DOG EARS INSIDE THAT SPIN OUT AND GRAB THE FLYWHEEL WHEN IT TURNS)
Sep 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
When I pull the cord it makes a snapping sound and does not turn the engine over. If I pull it slowly it will turn the engine over but I can't pull it hard enough to start it.
Pull the spark plug, and then pull the motor thru a few pulls. Clean the pull with small wire brush, and reinstall. If the motor still pulls hard, it may have gotten moisture in the fuel.
drain fuel completely and pour fresh in.
Jun 21, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
HP DeskJet 895cxi InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
