Question about HP PSC 1315 All-In-One InkJet Printer
Cartridges are stuck, cannot print
When I start printing the printer moves paper to its 1/3 and stops. The cartridges are trying to go to the paper area but they cannot, it is like something is bothering them and also paper moves 1cm forth and backward. When I open the front cover the cartridges move well and when I only make the paper go through it moves well without jam.
Hi all.
I broke the printer and threw it away.
Please consider the problem solved.
Posted on Jun 19, 2009
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Paper gets stuck halfway
    Fuser problem:
    start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 15, 2010 | Samsung ML 1610 Laser Printer
    Paper jam cleared but wont start
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage moves freely, skip to Step five .
    3. Remove the print cartridges.
    4. Gently move the print cartridge to the far right of the printer.
    5. Remove the paper from the paper In tray, but do not remove the drawer.
    6. Remove the rear access door.
    7. With your fingers, rotate the rollers "up" three full rotations.
    8. Push the rear access door back into the printer until it snaps firmly into place.
    9. Replace the print cartridges.
    10. Plug the power cable into the HP All-in-One.
    11. Turn the power on.
    Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
    Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
    Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    It starts printing, then stops, the printer cartrige is jammed
    Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
    If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
    Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
    The print cartridge cradle cannot move.
    "The print cartridge cradle cannot move."
    I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
    Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
    Paper Jam in HP Deskjet F2100 All in One
    1. Check for and remove any paper stuck in the paper in tray
    2. clear the paper jam from the back of the printer
    a. unplug the AIO
    b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
    c. gently pull the paper out fo the rollers
    d. clean the rollers with a lint free cloth that is moist with distilled water
    3. Lift the front cover and slowly remove any jammed paper
    a. unplug the power cable
    b. if necessary pull the input tray down to open it. then lower the print cartridge door
    c. gently pull the paper out of the rollers
    d. close the print cartridge door
    e. plug the power cable
    4. Verify that the print cartridge carriage can move freely
    b. check to see if the print cartridge carriage can move freely from one side to the other.
    c. remove the print cartridges
    d. gently move the print cartridge to tyhe far right of the printer
    e. remove the paper from the paper in tray, but do not remove the drawer
    f. remove the rear acces door
    g. with your fingers rotate the rollers "up" three full rotations
    h. close the rear access door
    i. replace the print cartridges
    j. plug the power cable
    k. turn the power on
    5. reload and test the printer
    Aug 06, 2008 | HP Office Equipment & Supplies
    Printer is not working
    Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
    May 15, 2008 | Canon Office Equipment & Supplies
    Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
    Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
    Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
    Printing
    It's a long shot, but there may be some paper stuck inside the toner cartridge. This happens occasionally. Be careful not to scratch the blue photo drum! Try replacing the cartridge.
    Feb 13, 2007 | HP LaserJet 2500 Printer
    Lexmark Z11 Printer will not work
    i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
    Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
    HP PSC 1315 All-In-One InkJet Printer Logo
    77 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
