Question about Maytag MBF2258XEQ
Bottom freezer has ice collecting
Sheet of ice is forming on floor of bottom freezer.
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Posted on Aug 09, 2009
SOURCE: Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
mrfixit3667
  • 262 Answers
SOURCE: MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Posted on Jul 04, 2010
allbrands
  • 600 Answers
SOURCE: Ice collects on bottom of
Hello, Thank You for using FixYa. I will be helping you today.
You have a frozen drain. You need to remove the back panel in the freezer. Do not touch anything behind the panel and dont poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaparator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number 8055306 Just push it on the end of the drain line.
Thank You and please rate my answer if it was helpful..
Posted on Jun 28, 2011
machinetech7
  • 1344 Answers
SOURCE: Ice forming inside freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
Posted on Apr 28, 2012
Testimonial: "Thanks for your help! Following your directions, I was able to fix my problem."
Whirlpool GZ25FSRXYY2 refrigerator/freezer- Sheet of ice collecting on bottom of freezer and then melting into floor- 3x over past month.
check for a clogged drain tube that goes thru the bottom to the drain pan where water is supposed to evaporate
Aug 02, 2015 | Whirlpool Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Where is the defrost drain
Back behind the metal "wall" at the rear of the freezer, there is a raised "shelf" with the drain in it. Pull our freezer racks or shelves, remove a few screws, renove sheet metal "wall", and you will find it at the bottom there.
Jul 22, 2014 | Maytag Refrigerators
Apr 28, 2012 | Maytag Refrigerators
Excessive "fog" in freezer causing
Check your door gasket. Cleaning the gasket should help it seal again
Nov 27, 2017 | Maytag Refrigerators
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag MBF2258XEQ Logo
15 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
