Question about Dewalt 18 Volt Compact Drill Kit
How to remove dw 988 chuck
Howto remove and replace dw 988 chuck
    Sniper:
  • 79 Answers
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Lemme know. Please rate me
Posted on Jun 18, 2009
Assembly manual for DW-988 heavy duty cordless drill
Request the manual from the manufacturer/distributor.
Nov 05, 2016 | Drills
Where does the green wire connect from the power cord on a dewalt dw 236 drill
The green wire is always the ground pin (ground connection)
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
I have a Magnetic Drill Press DW 151, and I am trying to replace the chuck. I can not figure out how to remove the chuck. Any help would be nice thank you.
WARNING !! SOLUTION # 1 BY dleemacc_0.jpgDarryel Hubbard
IS WRONG . FOR THE DEWALT
Magnetic Drill Press DW 151I ALMOST DESTROYED A $500.-!,000 DRILL READING HIS ADVICE
THE ABOVE DRILL HAS A 1/2" X 20 THREAD THAT THE CHUCK
THREADS ONTO. LEFT TO REMOVE AND RIGHT HAND TO REPLACE YOUR NEW CHUCK . YOU CAN TAKE A PIPE WRENCH AND AFTER PLACING THE DRILL ON THE SIDE PUT THE PIPE WRENCH AT/ON THE END OF THE OLD CHUCK AT ABOUT 2 o'clock. Once set up slap
the pipe wrench very hard/fast with a suitable hammer . It took about three times to knock the chuck loose and then I removed it with my hands. A little crude but it worked. Have a good one.
Dave Shelby
Jul 15, 2011 | Dewalt DW151 magnetic drill presses
We have a chuck that got jammedand broken, is it possible to remove the chuck only and replace it or do u only get the whole front section with chuck. And if the chuck can be removed, how do u remove it....
With the chuck open as far as possible, look within the jaws of the chuck for a bolt or screw head that attaches the chuck to the shaft. Remove the bolt/screw and remove the chuck. Some chucks can also be screwed onto the shaft, so look for signs of threads at the base of the chuck. Otherwise, once the bolt/screw is removed, tap along the outside around the chuck with a plastic hammer to loosen the chuck. Penetrating oil will help.
Take your chuck with you to a "big box" type hardware store, where a replacement should be available. Any well stocked hardware store should be able to help you. I have found that the somewhat smaller hardware stores are usually staffed with knowledgeable persons, and getting a replacement ordered is easier. One is more likely to be stocked in the larger stores.
The name brand of the chuck isn't as important for a replacement as is the correct shaft size and style of fit.
Best regards, --W/D--
Jun 15, 2011 | Chicago Pneumatic RP9790 STANDARD GRIP...
How do i remove a dewalt chuck in the DC 988 drill ?
go to the tip section and I left detailed instructions on how to do this, or try and go to my profile page under tups. Let me know if you still need more help
Oct 23, 2010 | Dewalt DC988ka 18 - volt XRP 1/2''...
How to replace the hammer and striker
Sorry I couldn't be of more help. I've looked at about every DV 20 version parts list and cannot find a part 16 that would create any difficulty in removing. All are either gears, pins, or the plate that goes under the switch. from the way you are describing it it sounds like the only possibility would be the Model DV 20VB which has a spindle which has to be unscrewed from the drill chuck it is held in by a retaining clip that you would need retaining ring pliers to remove.
Feb 11, 2010 | Hitachi Drills
I have a DeWalt DW 235G drill that needs a new chuck. How do I get the old one off. I took out the screw ...then what?
Put the small end of a 1/4" allen wrench in the chuck and close the chuck on the wrench the place the drill on your bench with chuck hanging over the edge and hit the allen wrench with a hammer and it will shock the chuck loose. Hold on to the other end of the drill when hitting allen wrench.Reverse for reassembly
Jan 24, 2010 | Dewalt Drills
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
494 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
