Question about Air Tools & Compressors
Kubota v2203 engine smokes badly and has a blow by
j_del
  • 1586 Answers
SOURCE: engine blowing thick smoke from exhaust
It's likely that the bad bearings and resultant oil seepage from the bad turbo caused oil to pool up in the intercooler piping (this is common). With a new turbo in there, you won't have further oil seepage, so the remainder of the oil in the piping should burn off. Over the next little while, you should see the amount of smoke coming out continue to diminish. If it does not, and is still smoking in a week or two, post back up on here and we'll take it from there.
Posted on Oct 16, 2008
SOURCE: kubota V2203
http://www.container.carrier.com/Files/Container/Global/US-en/62-10865.pdf
Posted on Nov 13, 2008
  • 9 Answers
SOURCE: kubota kh 91 excavator, blowing lots black smoke
If the Air filters are NOT restricted in any way and it's not skipping ( indivual cylinder problem ), check the small return line coming from the injectors going to tank for blockage. This will be a small line probably held on with a worm gear clamp. Good luck
Posted on May 19, 2009
  • 342 Answers
SOURCE: on kubota v2203 i drilled thru a frost plug while
replace the sleeve if they are removable if not find a specialist wlding and machine shop
Posted on Apr 04, 2010
  • 18 Answers
SOURCE: my T1760 blows white smoke for 60 sec when starting
You have to check for a coolant leak into the cumbustion chamber. This unit is liquid cooled. Check coolant level and check head bolts for torque
Posted on Apr 25, 2010
Kubota t1560, Why did my oil turn black? Why would black smoke come out of exhaust also?
OIL RINGS are shot . possibly or you are burning too much fuel
Jul 28, 2016 | Kubota Garden
Where is the drain plug for the block drain on a Kubota engine V1902-B?
[PDF]KUBOTA DIESEL ENGINE - Waterax
waterax.com/app/uploads/2015/09/ENGINE-MANUAL-D902.pdf
engine maintenance. it is KUBOTA's policy to utilize as quickly as possible .... Be sure to close the coolant drain valve, secure the pressure cap. and fasten the .... Oil drain plug. (18) Oil ... around the machine. it may catch on moving (B) "OFF".
Kubota V2203 Block Water Drain? - Diesel Bombers
www.dieselbombers.com > ... > Diesel Engine Conversions
Nov 21, 2013 - On my Kubota V2203 DI above the Oil filter is a long bolt of which the only thing ... I did not even know that Block Water Drain was there till last night I ...Also, the pipe plugs in the engine are a Japanese style, but we've ... Kubota v2203 vsv1902, ziegler, Diesel Engine Conversions, 4, 01-10-2015 06:27 PM.
Kubota Engine Service Tips
johnsoncitykubota.com/Kubota%20Engine%20Service%20Tips.htm
If the reading is 11 volts or more while you are trying to crank the engine see the ...Other causes include defective glow plugs or low cranking speeds from a weak battery.... We have not seen it "ruin" anyone's tractor yet, so drain the tank, refill with ....passages between the cylinder head and the block became 90% blocked.
Kubota L2550 needs block heater! - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tractors
Jan 25, 2011 - 25 posts - ‎14 authors
Oldmax, I could swear I was looking at a closeup of my engine, except for the colour.... V1702, V1703, V1902, V1903, V2003, V2003T, V2203 (4 cylinder) Part No. ... BSeries (Except 2 cylinder) Part No. Watt Volt Diameter Type .... Paul, does the tractor have a block drain plug, and a thermostat bypass ...
Jan 06, 2016 | Cars & Trucks
My KX 41 kubota mini excavator is smoking
Valves need ground, injectors overfueled, if a lot hours, rings maybe bad.
Jan 26, 2014 | Garden
Need to know what the specs are for v2203-e head bolts torque
Do you mean a Kobuta v2203 e diesel engine? This looks to be in the Air Compressor section?
Anyhow, the specs for that are here: http://www.frontierpower.com/kubota/oldkubota.htm#Super3
Jan 12, 2011 | Air Tools & Compressors
My 21 HP diesel zero turn mower starts blowing black smoke after running at higher throttle settings and temp gauge shows engine is warm. No air restrictions. New fuel filters. smooth running when cool or...
Looks like you've got a good idea on what makes diesels smoke, so I'm sure you know that black smoke is almost always from too much fuel for the air that's going in. So it can be too much fuel or too little air. If your filters are good, the next things to check are the fuel pressure and the injectors.
I know diesels, but I don't have any specific experience with lawn mowers (kubota?). Since it stalls eventually, it sounds like it's not a single cylinder (although not for sure) so I'd check injector pump first.
Sep 28, 2009 | Garden
Kubota kh 91 excavator, blowing lots black smoke
May 06, 2009 | Garden
00 ford focus wagon a/c & engine smoke problem
Engine smoke problem-- Automatic, chk transmodulator. If oil in vacuum line, modulator is defective. Engine sucking up trans fluid. 10.00 fix . good indicator is smoking at cruising speed or deceleration.
Bad rings smoke under acceleration and bad valve guides smoke on deceleration. poor crankcase ventilation (pcv valve) will cause engine leaks and oil blowing out of dipstick. Good Luck
May 05, 2009 | 2000 Ford Focus
Engine blowing thick smoke from exhaust
Oct 16, 2008 | 2001 Volkswagen Passat
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
