Question about Braun SyncroPro 7785 Electric Shaver
Cord 7785 cord broken
I need to know if the coach purse is real or not
The best way to know is by the price that you paid for it. If you got it for 50 % or more off the regular price than it is probably a look a like fake. The model or serial numbers cannot be used to identify a fake either because they make them the same as on genuine items.
Oct 31, 2015 | Clothing Accessories
Need zip code for Mitchells Plain Cape Town
It is 7789 for a street, 7785 for a PO Box
Jan 30, 2014 | GPS
I have tried to post my question several times, asking how to change the pull cord on my Poulan 625 series lawn mower, it hasn't posted and I can't seem to get an answer.
did this break at the pull handle? if so you will still be able to re-use the same cord.
you have to first remove the pull mechanizum from the top of the engine. turn it upside down and get the old pull chord off 'If it has broken at the engine end of the cord. You will find the end of the cord inside, remove it with a pair of pin nosed pliers.
If broken at the pull handle remove the broken and of the cord from the back side of the handle. There will be a knot tied in either end. Assuming you still have enough pull cord . Cut the broken end so it is not frayed slip it through the pull handle and tie a simple knot & make it tight with some pliers.
re wind the spring by hand winding the cord back into the spool.
now you need a small zap strap to hold it all in place until you reinstall the pull mechanizum on top of the engine.Once you have done this cut the zap strap off and retrieve it as you do.
Hint* "with only 2 hands" I have used pin nosed vice grips to hold back the spring while I tie it off with zap strap or stiff string.
If the cord if broken at the engine end you will need to line up the cord input with the cord journal and hold in place while you try to feed the cord back through. Hint* use a smaller peice of wire to feed through the opposite direction and wind it around the cord several times so you can pull it through to the inside of the pull mechanizum and tie a knot. Good luck
Oct 12, 2013 | Garden
CAN'T GET RID OF DEMO MODE
go to your instr. manual and proceed according. or download it from
www.retrevo.com
God bless you
Oct 15, 2012 | Microwave Ovens
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
Laptop doesnt work
if the power cord is broken, you need to buy a new one... bring the broken cord to the store if you want to purchase a new.. so that they will give you the right power cord for your laptop...
Jul 20, 2009 | Battery Technology for Toshiba Satellite...
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Braun SyncroPro 7785 Electric Shaver Logo
21 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
