Question about John Deere Ar50041 Diesel Fuel Filter 3020 4030 4440 ()
What is the procedure to change fuel filter AR50041?
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
How to change the fuel filter to a 1993 BMW
You will need fuel line block off clamp
Mar 01, 2012 | 1990 BMW 525i
How do you change the fuel filter on a 96 Olds Cutlass Supreme 4 door 3.1 V6? Vin#1G3WH52M8TF372414
Fuel filters are easy to replace but let me give you some friendly warnings:
CAUTION. To reducethe risk of fire and personal injury always follow the correct procedure for disconnecting and connecting fuel pipe quick connect fittings. This will ensure good connections and prevent possible fuel leaks.
CAUTION. Safety glasses must be worn if you use compressed air, as flying dirt prticles may cause eye injury.
Important
The fuel filter is no longer serviced in regular maintenande intervals. It is only necessary to replace the fuel filter in the case of damage or a clogged filter.
Before replacing a fuel filter it is necessary to relieve fuel system pressure.
Your fuel filter is located under the vehicle, driver side, below seating area, front of fuel tank, mounted on frame rail in fuel line
Fuel filters and elements are serviced by replacement only. Some vehicle manufacturers recommend fuel filter replacement at 30,000 miles (48,000 km). Always replace the fuel filter at the vehicle manufacturer's recommended mileage.
The fuel filter replacement procedure varies depending on the make and year of the vehicle and the type of fuel system. Always follow the filter replacement procedure in the appropriate service manual. The photo sequence below shows a typical procedure for relieving fuel pressure and removing a fuel filter.
Removing a Fuel Filter on an EFI Vehicle
fps23-01.jpg Disconnect the negative cable at the battery.
fps23-02.jpg Loosen the fuel tank filler cap to relieve any fuel tank vapor pressure.
fps23-03.jpg Wrap a shop towel around the Schrader valve on the fuel rail and remove the dust cap from the valve.
fps23-04.jpg Connect the fuel pressure gauge to the Schrader valve.
fps23-05.jpg Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
fps23-06.jpg Place the vehicle on the hoist and position the lift arms according to manufacturer's recommendations. Then raise the vehicle.
fps23-07.jpg Flush the fuel filter line connectors with water, and use compressed air to blow debris off and away from the connectors.
fps23-08.jpg Follow the recommended procedures for disconnecting the fuel inlet connector.
fps23-09.jpg Art courtesy of Delmar - Thomson Learning.
Follow the recommended procedures for disconnecting the fuel outlet connector, then remove the fuel filter.
Installing Fuel Filters
In-line fuel filters are installed in the fuel line. In carbureted engines, the in-line gasoline filter is usually installed between the fuel pump and the carburetor. In vehicles with a fuel injection system, the location of the fuel filter is determined by the manufacturer. An arrow on the filter shows the direction of fuel flow.
  • To install a new filter, begin by wiping the male tube ends of the new filter with a clean shop towel.
  • Apply a few drops of clean engine oil to the male tube ends on the filter.
  • Check the quick connectors to be sure the large collar on each connector has rotated back to the original position. The springs must be visible on the inside diameter of each quick connector.
  • Then install the filter in the proper direction and leave the mounting bolt slightly loose.
  • Install the outlet connector onto the filter outlet tube and press the connector firmly in place until the spring snaps into position.
  • Grasp the fuel line and try to pull this line from the filter to be sure the quick connector is locked in place.
  • Then, do the same with the inlet connector.
  • Now tighten the filter retaining bolt to the specified torque.
  • Once everything is connected, lower the vehicle, start the engine, and check for fuel leaks at the filter.
Have fun and all the best
Ben
May 22, 2011 | 1996 Oldsmobile Cutlass Supreme Coupe
How do i change fuel filter
2002 Dodge Caravan
Fuel Filter Replacement Procedure
1. The fuel filter is located on top of the fuel tank near the fuel pump module. Fuel lines are permanently attached to filter assembly and must be replaced with the fuel filter.
2. Release pressure from fuel system by removing the fuel pump relay and start the engine and let it die. Crank the engine a couple times after it dies to relieve more of the fuel pressure
3. Disconnect negative battery cable
4. Raise and support vehicle
5. Support fuel tank with transmission jack or floor jack with large plywood board to evenly distribute the weight of the fuel tank. NOTE: It is important to distribute weight evenly to prevent damage to the fuel pump module.
6. Disconnect ground strap from fuel tank
7. Remove inboard fuel tank straps and front "T" strap fastener
8. Lower the fuel tank approximately 6 inches to access the fuel filter assembly.
9. Disconnect the fuel lines at the fuel supply connector and the fuel pump module
10. Remove the retaining bolt and remove filter assembly from vehicle.
11. Reverse removal procedure to install (Don't forget to put the fuel pump relay back )
Apr 02, 2011 | 2002 Dodge Caravan
Fuel filter leaking around the back of it filter# ar5oo41 and need know how to change it james vincent
It just snaps on/off...make sure you fill with fuel before you replace it..thus you wont need to prime it as much
Jan 23, 2011 | John Deere Ar50041 Diesel Fuel Filter 3020...
Changing fuel filter
I would look near the fuel pump for it and it is a very simple procedure.Thanks for asking and I hope it helps.
Jul 21, 2010 | 2001 Oldsmobile Alero
How do I install fuel injectors on a 3406E Cat
This Should be done at a dealer or by someone experianced.
There are several special instructions that have to be followed
as well as a special injector height tool required to set the injector.
Jun 05, 2010 | John Deere Ar50041 Diesel Fuel Filter 3020...
Where is the fuel filter located on a 2005 Lincoln LS? I drove my LS just before empty. Now I notice when I'm driving it's a little sluggish when trying to accelerate. I would like to change the fuel...
The fuel filter is behind the driver's side wheel. Here is the procedure....
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Relieve the fuel system pressure.
  3. Disconnect the negative battery cable.
  4. Remove the left front wheel well rear splash shield.
  5. Disconnect the fuel tube quick release fittings from both sides of the fuel filter.
  6. Remove the fuel filter bracket mounting bolt, fuel filter bracket, and the fuel filter.
To install:
  1. Install or connect the following:
    Fuel filter into the bracket making sure the flow direction is correct. Tighten the clamp to 15-25 inch lbs. (2-3 Nm). Fuel lines. Tighten the fittings to 22 ft. lbs. (30 Nm).
  2. Tighten the bracket bolts to 62 inch lbs. (7 Nm).
  3. Start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | 2005 Lincoln LS
How to change fuel filter on 1999 olds 88 with v6
Locate the fuel filter. One side will unscrew using a 16mm open end wrench on the pipe, and hold the fuel filter with a 20mm wrench, and unscrew. The other side of the filter has quick disconnect fittings. Press the tab ears in and pull the line away from the fuel filter. Be careful, fuel will come out when you disonnect the lines. install in reverse procedure.
Mar 01, 2010 | 1999 Oldsmobile 88
John Deere Ar50041 Diesel Fuel Filter 3020 4030 4440 () Logo
54 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
