Question about Tricity Bendix Washing Machines
My tricity bendix eco 4 1000 autowasher leaks from drawer. This doesn't happen every time the machine is used. Have cleaner the drawer but it still keeps happening.
    Genius:
  • Tricity Bendix Master
  • 1,585 Answers
Check hose at bottom of drawer
Posted on Feb 23, 2015
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
jumptrout51
  • 3361 Answers
SOURCE: i have tricity bendix eco machine but there is
Use AFFRESH product in the washer.
Front load washers share this smelly problem.
Posted on Feb 21, 2009
FitzOriginal
  • 842 Answers
SOURCE: THE FABRIC SOFTNER DRAWER IS ALWAYS FULL OF WATER
This is usually because the fabric softner draw is prone to colgging due to a build up of gunk in the holes that drain the softner into the machine at the appropriate time. Remove the drawert (There is usually a thumb press release at the back of the drawer you will see if you pull it out as far as you can.
After removal, wash the drawer all over (paying particular attention to the bottom of the drawer). If you have a garden hose, take the drawer outside after you have cleaned it and turn the hose on, full belt, and blast out all the waterways in the drawer to make sure they are clear. Refit the drawer and this should sort out the problem
Posted on Oct 09, 2009
Daniel S
  • 4323 Answers
SOURCE: tricity bendix aw1002w front loading
Hi
The issue is either with bad door lock-switch assembly or the control board that is bad and should be replaced. You can take the control apart and check the wires & also if any button is stuck you can unstick that and if the issue returns replace the control board. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 23, 2011
ginko
  • 19396 Answers
SOURCE: TRICITY BENDIX AUTOWASHER 800 WASHING
Hi.
Problem is likely the thermostat. Before replacing internal thermostat check the following:
Tricity Bendix Autowasher models are usually not self heating and dual inlet (hot and cold). If the machine is not self heating, ensure that the inlets are not inverted. Ensure that both inlets have enough pressure.
In case the machine is self heating, check also that the washer is not heating in cold cycle, otherwise you will need to check wiring to heating element.
To get parts contact Tricity Bendix at the number listed in the owners manual, or give us the full model number, as written on service tag.
Regards.
Ginko.
Posted on Feb 10, 2011
How to tell weather my second hand tricity bendix eco plus 50:50 is going to refridgerate and freeze my food left it stand upright for 4 hours before switching on ?
Hi, you should see ice forming in the freezer compartment after an hour or two and if you have a fridge temp gauge it should show the temp of your fridge .
Jan 28, 2016 | Tricity Bendix Washing Machines
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix wdr 1241 emergency drain hose leak
Pull the machine out, if the back is removable, take it off. the connection should be close enough to reconnect...next time? don't pull so hard. if this doesn't work, take it to a reputable Repair Shop/Dealer
Oct 15, 2012 | Tricity Bendix WDR1240W Front Load Washer...
THE FABRIC SOFTNER DRAWER IS ALWAYS FULL OF WATER ON OUR TRICITY BENDIX 1000 WASHING MACHINE
Oct 09, 2009 | Tricity Bendix Washing Machines
Bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
Jul 13, 2009 | Tricity Bendix AW1000W Front Load Washer
Is my bendixx 1000 autowasher hot or cold fill
Look at the top left rear of the cabinet, there you will see the connections for the inlet valve(s), if there is only 1 then it is a cold fill only, if there are 2 connections , then it is hot and cold fill.
They are normally marked H and C.
Plz leave feedback for this solution.
thanks.
Dec 17, 2008 | Tricity Bendix WDR1040W Front Load Washer...
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
