Question about ZTE Verizon Jetpack 4g/3g Mobile Hotspot verizon Wireless
Mi-fi vERIZON ac adapter instead of battery
    Novelist:
  • 188 Answers
This device will operate as intended with either of the power sources mentioned.
Posted on Jul 26, 2014
Pandigital wi-fi usb adapter
I want to buy one - or something that will work. Any suggestions? I underestand that Pandigital is out of business, so what could I use instead?
A: i dont know! apologies.
THANKs, ding
Apr 25, 2017 | PANDIGITAL Computers & Internet
My verizon jetpack MHS29IL shut down and won't turn back on
Is it plugged up or running on battery power? If it is on AC, try another socket instead of the one used now. If it doesn't turn on while connected to AC then it is likely defective and should be returned. But, just to double-check, try a new battery or a different charger and make sure it is securely plugged into the battery charging port.
May 23, 2014 | Verizon Wireless Jetpack 4G LTE Mobile...
My ipad not charging but the usb cable and the ac adapter is working
You can check to insure your ac adapter is working by substituting other adapters and cables, and see if they work with other devices.
Remember that iPads require more current than is available from most USB adapters. You will typically need 2.3 amps of power at 5 volts. If you have an adapter that will only put out 1 amp or less, your iPad will not charge because your adapter is under powered.
Jan 27, 2014 | Apple iPad 3 Tablet 32GB Black WI-FI 4G...
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Got new Verizon jetpack today..have a d-link device...won't connect.....previous Verizon mi-fi worked fine????
Well, sorry to say you have struck out, first it's Verizon, then a JetPack and finally D-Link. The only way I was able to get mine working was to switch to a Cisco device for the link, drop the D-link!
Oct 24, 2013 | E-Machines eMachines Desktop PC
Toshiba A35 S159
you forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Sep 28, 2009 | Toshiba Satellite A35-S159 Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Dead laptop
take out the battery of the laptop and try starting it on the AC adapter,
if it doesn't work, if your friend has the sam ac adapter try starting your system with a different Ac adapter, if nothing of this works
call your laptops technical support
Further Queries are welcome
If you think my solution was helpfull please do rate me
Feb 21, 2009 | Computers & Internet
A35 s1592 battery won;t charge
You probably have a problem with your power adapter. Since you mentioned that the battery discharges when connected to the adapter, it means that the charger is acting as a load instead of the other way around. This is a typical behavior of a defective charger.
Try to check the output of your adaptor using any voltmeter. The voltage reading should be approximately close to the voltage rating as printed at the back of your laptop. If not, then its wiser to buy a new ac adapter instead of sending it for repair to electronic shops. Most of these chargers are no longer reliable when repaired, and might cause more problem to the laptop instead.
Nov 09, 2008 | Toshiba Satellite A35-S1592 Notebook
ZTE Verizon Jetpack 4g/3g Mobile Hotspot verizon Wireless Logo
184 people viewed this question
Top ZTE Computers & Internet Experts
Lawrence Oravetz
Are you a ZTE Computer and Internet Expert? Answer questions, earn points and help others
