Question about Coby MP-610 MP3 Player
When transferring I get an error called encoder.exe popping up
    President:
  • 828 Answers
Thats a virus or trojan... remove all spyware and trojan in your pc... here is the site to help you that out http://leerz25.sitesled.com
Posted on Jun 18, 2009
How do I delete error message pop reading, Windows cannot find C:\Program Files (x86)\RocketTab\cClient.exe.
Open the 'C:\windows\system32\tasks' directory. Locate and delete all files containing the word 'Rocket'. IMPORTANT: DO NOT DELETE the RTKCPL file. This is a legitimate Windows file. Restart your computer. The error should not return.
Oct 28, 2014 | HP G60 Notebook
Tip
Transferring Videos to Iphone
Well as you may know the iPhone 3G plays only mp4 files. There are several expensive video encoders out there but here's how you can get one for free. You will need to download eright super. A free ware from erightsoft.com.
http://www.erightsoft.org/GetFile.php?SUPERsetup.exe
Then install the software on your comp. Run super and choose your device(iphone 2g, 3g) etc., The drag and drop the video file to be encoded into the list.Choose the sound quality(160 k-bits for best quality) and video quality(640x480 is the highest) You can also choose the aspect ratio 4:3 works best for my phone(iPhone3g). Click on encode. The encoded file will be placed in the output directory. Ex: If you installed it in c:\Program Files\Super
then you will find the encoded file in c:\Program Files\Super\output.
After this you can download itunes8. The best part is that itunes8 unlike the previous versions allows you to drag and drop videos to your iphone. Thats it!
on Sep 29, 2008 | Apple iPhone Smartphone
Is setup.exe.vbe safe to run?
probably not. .vbe means Visual Basic Encoded script. It seems as though someone tried to camouflage their script with a familiar filename (by prepending setup.exe in front of it. Is this on a CD or a file you received in email or downloaded?
Feb 04, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have a 123 copy DVD gold software and can not copy a DVD because the software showed a pop up information "can not open demuxer". how can i solved this problem?
If the "Cannot open demuxer" error appears it means the Avi encoders on your system are either missing or corrupt.
To uninstall Windows Media Encoder, apply the following steps. 1.Go to control panel 2.Click on add and remove programs( Programs and features for Vista and Windows 7) 3.Click on Windows Media Encoder 4.Click on remove button 5.Click on next button 6.Then continue according to the instruction provided by the Encoder's Uninstaller
Reinstall your codecs.
DIVX http://www.divxmovies.com/codec/
XVID http://www.xvid.org/Downloads.15.0.html
Windows Media Encoder WMV - www.123copydvd.com/apps/WMEncoder.exe
Jun 30, 2011 | Bling Software 123 Copy DVD Gold 09
I have a 97 Chevy blazer with push button 4 wheel drive and it don't shift In to 4 low or 4 hi and the light should flash for 30 second then go back to 2 hi if it can't shift but when you push the button...
How about to the switch , is there battery power ? Fuse #15 FWD 10amp. I/P fuse panel . BCM - body control module light's the switch indicators 2hi, 4hi,4low . Check fuse #6 10amp I/P fuse panel .
DTC 002
The transfer case encoder motor is an assembly which houses four separate channels. These channels are used to indicate to the transfer case shift control module the present gear position of the transfer case or if the transfer case is in transition between gears. The encoder motor assembly consists of an electronically conductive inner ground ring in contact with a three legged wiper arm. Each leg's length is such that it makes contact with the conductive regions of the four channels. When any leg of the wiper arm is making contact with the conductive area of any channel, the encoder provides a path to ground to the inner ground ring.
During electronic shifting, the transfer case shift control module monitors the transfer case encoder circuit for the proper operating sequence. If at any time during a shift, the encoder changes from one position to any position other than the next possible position, an error counter in the transfer case shift control module increments by four. After the counter reaches 32, the transfer case shift control module set a DTC 2, a permanent "encoder fault," and reverts to a 2HI to 4LO or a 4LO to 2HI shift pattern only. To guard against a transient, random encoder fault due to vibration, dirt, electrical noise, etc., the fault counter reduces by one each time the transfer case shift control module detects a valid encoder value. The encoder must intermittently fail 25 percent of the time for the transfer case shift control module to consider it faulty and store DTC 2.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step measures the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
This step tests the suspect circuit(s) for an open, short to power, or short to ground.
This step tests the encoder signal ground circuit for an open or high resistance.
DTC 2 -- Encoder Fault Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Important: Check the transfer case shift control module for DTCs. The transfer case shift control module is not a class 2 device. DTCs are displayed on the transfer case shift control switch. Use the following four steps to obtain DTCs.
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes.
Did you perform the Diagnostic System Check - Transfer Case?
YES - Go to Step 2
NO - Go to Diagnostic System Check
Disconnect the connector at the encoder motor.
Measure the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
Does the voltage measure near the specified value?
4.8-5.1 V
YES - Go to Step 4
NO --Go to Step 3
Test the suspect circuit for an open, short to power, or short to ground. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 8
NO - Go to Step 7
Turn the ignition switch OFF.
Test the encoder signal ground circuit for an open or high resistance. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
YES - Go to Step 8
NO - Go to Step 5
5
With a DMM at the transfer case module connector probe the encoder sign ground pin and ensure a good ground path through the module.
Did the DMM indicate a good ground path?
YES - Go to Step 6
NO - Go to Step 7
6
Replace the transfer case encoder motor. Refer to Motor/Encoder Replacement .
YES - Did you complete the replacement?
NO - Go to Step 8
7
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
NO - Go to Step 8
8
Clear all DTCs from memory. Refer to Diagnostic Trouble Code (DTC) Clearing .
Operate the vehicle while pressing each of the buttons on the transfer case shift control switch.
Does the DTC reset?
YES - Go to Step 2
NO - System OK
Aug 29, 2017 | 1997 Chevrolet Blazer
ERROR HADWARE 03130031-2F26
this error code pops up again or is replaced with the f13 message...solution..wheel the printer to your companies parking lot and take a fire axe to it on your lunch break and never buy a canon product again.
Jul 09, 2009 | Canon imagePROGRAF IPF710 Printer
Where is the 4x4 encoder motor sensor located on my 03 sierra
the encoder motor sensor is inside the encoder motor. the encoder is located at the transfer case. Remove the encoder and by part number 88962315 this is the sensor. you will have to retime the motor after
hope this helps
Feb 16, 2009 | 2003 GMC Sierra
Denali slips in and out of 4x4
How may buttons for the 4X4 two , three , or four ? Do the lights flash ? Any messages - service four wheel drive system ? Which transfer case does it have ?
Transfer Case - NVG 246-NP8 (Two Speed Automatic)
The transfer case shift control module uses the VIN information for calculations that are required for the different calibrations used based on axle ratio, transmission, tire size, and engine. The system does not know which calibration to use without this information.
Transfer Case Encoder Motor
The transfer case encoder motor consists of a permanent magnet (PM) DC motor and gear reduction assembly. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case (clockwise or counter clockwise) to shift the transfer case. The encoder motor is controlled with a pulse width modulated (PWM) circuit within the transfer case shift control module. This circuit consists of a driver on both the Motor Feed A and Motor Feed B circuits. The encoder motor is bi-directional to allow the motor to shift the transfer case from 2HI or 4HI to NEUTRAL and 4LO positions.
The encoder is mounted to the transfer case encoder motor assembly and is replaced as an assembly. The encoder converts the sector shaft position (representing a mode or range) into electrical signals inputs to the transfer case shift control module. The module can detect what position the transfer case is in by monitoring the 4 encoder channels (P, A, B, and C). These inputs translates into AUTO 4WD, 2H, 4H, NEUTRAL, and 4L or in transition between gears.
Transfer Case Motor Lock
The transfer case motor lock is used to provide a 2H, 4H, and 4L lock-up feature. When the lock circuit is energized, the transfer case encoder motor is allowed to turn. When the transfer case is placed 2H, 4H, or 4L the motor lock circuit has no power provided to it and the lock is applied. This assures that the transfer case remains in the current gear position. When AUTO 4WD is selected the motor lock remains applied until an adaptive mode (torque is applied to the front propshaft) is required. During an adaptive mode the motor lock circuit is energized and the motor lock is released, enabling the encoder motor to turn and apply torque to the front propshaft.
SERVICE indicator (4WD/AWD) Lamp
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via a Class 2 message or by a Sevice Indicator Control Circuit.
The first thing to do before assuming it's a loose wire would be to have it checked for codes , auto zone , advance etc... can not check this codes .
DTC B0768 Service Indicator Circuit High
DTC B2725 ATC Mode Switch Circuit Malfunction
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0308 Motor A/B Circuit Low
DTC C0309 Motor A/B Circuit High
DTC C0310 Motor A/B Circuit Open
DTC C0315 Motor Ground Circuit Open
DTC C0323 T-Case Lock Circuit Low
DTC C0324 T-Case Lock Circuit High
DTC C0327 Encoder Circuit Malfunction
DTC C0357 Park Switch Circuit High
DTC C0362 4LO Discrete Output Circuit High
DTC C0367 Front Axle Control Circuit High
DTC C0374 General System Malfunction
DTC C0376 Front/Rear Shaft Speed Mismatch
DTC C0387 Unable to Perform Shift
DTC C0550 ECU Malfunction
DTC C0611 VIN Information Error
If you know nothing about this , your best bet would be to take it to a qualified repair shop .
Apr 29, 2017 | 2000 GMC Denali
Fill system error in muvo v 200 usb
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=702,E=0000000000295070241,K=561,Sxi=1,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(4656),Kb=ww_english_add
Dec 03, 2007 | Creative Labs MuVo V200 MP3 Player
Coby MP-610  MP3 Player Logo
149 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
