Question about HEWLETT-PACKARD HP G56-122US Notebook
Scroll. And caps lock lights on but computer will not open
Why the caps lock and scroll light keep on blinking without entering to the window
The lock leds are used by some computer manufacturers as an error indicator. if you are unable to boot up and the lock LED's for caps and scroll are constantly flashing then it would indicate that your computer has most likely encountered a hardware error preventing it from loading. if you can add a comment with the manufacturer and model of your computer I can help you check the error
Mar 26, 2011 | Computers & Internet
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
Compaq Keyboard -- top right hand corner, the light next to the CAP LOCK is lit. What is this for?
Num Lock ----- Cap Lock ---- Scroll Lock
  • Num Lock --- use numeric keypad
  • Cap Lock --- all capital letters
  • Scroll lock --- stop screen from scrolling ( pause screen )
Feb 23, 2011 | Computers & Internet
Weird display light above the power button
those are status indicator lights with the following info:
Indicator Icon Description Modular drive modular.gif The computer is accessing the modular drive. Hard drive hdd.gif The computer is accessing a hard drive. Caps Lock statusd.jpg Caps Lock is turned on. Pad Lock statuse.jpg Pad Lock is turned on. Scroll Lock statusf.jpg Scroll Lock is turned on.
Apr 16, 2010 | Gateway 450SX4 Notebook
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
HEWLETT-PACKARD HP G56-122US Notebook Logo
14 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
