Question about Symbol Computers & Internet
Symbol Scanners I'm trying to scan an interleaved 2 of 5 barcode (length 24 with a check digit ... Symbol P300 Industrial Phaser
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
Why i cannot scan 1 digit number
Did you make the barcodes using Code 39 or 3 of 9? If so, the scanner defaults to reading between 2 and 55 character Code 39 barcodes. Go to the Motorola Solutions support portal and search for Article ADC-00404 portal motorolasolutions com. Print the article and scan the Code 39 Any Length barcode. Once this is done the scanner will read all Code 39 barcodes.
Aug 12, 2014 | Symbol LS 4278 Barcode Scanner
Symbol DS9808 will not scan barcode
Hello Dbird,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for DS9808.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Dec 02, 2010 | Zebra Symbol DS9808 Barcode Scanner...
HI I HAVE ONE MOTOROLA SYMBOL DS6707 BARCODE READER TODAY ONE PROBLEM OCCUPIED. ANY MOBILE IMEI CODE SCAN BUT BATTERY NOT SCAN. SO PLEASE HELP ME
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode. Set the scanner for two specific lengths or for any length of barcode. Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
Nov 04, 2010 | Symbol DS6707 Wired Barcode Scanner
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Oct 13, 2010 | Symbol LS 4000i Handheld
My Symbol LS2208 will not recognize Interleave 2 of 5.
You will need to download the product reference guide for this scanner: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=165642940&stateId=1%200%20165644142
once you have downloaded the file, go to the symbologies section, then the 2of5 section and scan the i 2 of 5 any lenght barcode
this will fix your problem
Thank you,
Kim Ganoe
kganoe@datexcorp.com
Mar 25, 2010 | Symbol LS2208 Handheld
I am scanning Interleave 2 of 5 barcodes into Notepad with a Symbol LS2208, and they won't scan. I can scan other types of barcodes and they work...what do I need to do to get it to scan Interleave 2 of 5?
Basically you need to program you scanner. I have manuals and sofware needed. I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Jan 13, 2010 | Symbol LS2208 Handheld
Scan a single digit character
i have problem with when i goint to scan after 5 or 10 minutes after it disable, and then we go to connect and disconnect to work
Nov 25, 2009 | Symbol LS 2208 Barcode Scanner
We are using Unitech PT630, HT630 for our stock audit at various retail outlets. we get wrong barcodes while scanning. Most of the times, scanner return only 4-6 charectors or part of the barcode is read...
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija. Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
May 12, 2009 | Unitech 630D PDT 2.5MBRAM LR CCD SCA
Symbol PDT 8100 and I2of5 barcode reading problems
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Feb 09, 2009 | Symbol MC9090 Barcode Scanner
Computers & Internet Logo
67 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
