Question about Sony KV-28FX60 28" TV
The tv keeps turning off and I replaced the bulb
Why won't the tv stay on. It comes on for 30 seconds and then goes off again.
  • 71 Answers
SOURCE: 36" sony trinitron wega tv pip
You guys have the same problem.
Unfortunately bad CRT. You can get a tech to regenerate it and it'll work for another year or 5-8 month after that... garbage.
Posted on Dec 07, 2007
jewellgirls
  • 12 Answers
SOURCE: Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Posted on Oct 16, 2008
jerryg50
  • 1667 Answers
SOURCE: PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Posted on Nov 25, 2008
egadgetguy
  • 258 Answers
SOURCE: menu box keeps appearing on the screen
There are meny reasons this might be happening. here are a few obvious ones.
1. The remote is under a cushion and buttons are being pushed.
2. The Sensor on the set is in the sun and the sun is confusing it.
3. You neighbor is messing with you
4. The set has a bad chip/loose connection/etc.
[you might try something as simple as unplugging it for a minute.]
5. it's set to 'DEMO' mode.
Ken
Posted on Jan 01, 2009
  • 26 Answers
SOURCE: screen goes black every few seconds but have a picture
Sony incorporates a video blanking circuit that blanks the picture out when the picture tube begins to get weak. sorry, but short of replacing the tube, there's no lasting solution to this problem. I used to have some success rejuvenating the crt, but I found that it didn't last but a few hours before the blanking circuit starts to activate again.
Posted on Apr 01, 2009
When I turn tv on it stays on for 30 seconds and then goes off again
it sounds like a fault do you see any indicators come on afterwards?
Aug 14, 2013 | Televison & Video
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Screen blanks after 30 to 60 seconds
change 22mf-200v near fly back .
Apr 10, 2010 | Sharp 25K-M100 25" TV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Mar 15, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KV-28FX60 28" TV Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
