Question about Swanstone Home
Cracked the the swanstone base during installation of walls.can it be repaired?
3 Suggested Answers
  • 4 Answers
SOURCE: hairline cracks on top edge of swanstone bone laundry sink
try tub and tile epoxy at home depot
Posted on Mar 27, 2009
slave2aslave
  • 302 Answers
SOURCE: Scratches on a black swanstone sink
You could try automotive buffing compounds. Make sure to follow the directions on the package.
I have heard of people using fridge/stove touch up paints as well,though I have never tried this.
Posted on Oct 06, 2009
Fix cracked swanstone
Other than purchase a new sink, if you have some pieces of the sink, sand those pieces with the sole purpose of collecting the dust. Make Use superglue in the crack -- try to get it just below 1/16 the surface in the cut. Brush (push with fingers) composite dust into cracks. Allow to an hour and try sanding with 220 Grit sandpaper.
Mar 03, 2014 | Tablets & eReaders
Cut a small line through swanstone granite sink when installing undercount . Fixed with epoxy. Will that work?
It should work, I would imagine it's pretty conspicuous, but you shouldn't have problems with leaking if the epoxy filled the hole completely. I would clean the repair on the outside of the sink with rubbing alcohol, then put a decent amount of silicone to completely cover the repair area to insure no water gets through if there are any compromises in the epoxy.
Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Feb 26, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
Swanstone sink with chip near the faucet but on the edge near the bowl. ANyway to patch this...a filler so to speak?
Unfortunately Swanstone does not have a repair kit for this type of damage. The chip will be permanant. They do offer a limited lifetime warranty which if a defect is found they will repair or replace at their discretion. Of course you will be responsible for any labour cost as per their warranty and they do not go into any detail on how to repair impact damage. For more information go to www.theswancorp.com
Aug 20, 2010 | Swanstone Home
Sep 20, 2009 | Home
Metal bracket with Corner Seat, is it installed prior to tile?
The metal bracket is applied after the tile. That is the reason for the reinforcement between the studs.
Mar 11, 2009 | Swanstone CS-1616 Corner Shower Seat,...
Home Logo
Top Swanstone Home Experts
Gene Haynes
Tony Crow
Are you a Swanstone Home Expert? Answer questions, earn points and help others
