Question about Canon imageRUNNER 2270 Copier
Canon ImageRunner 2270 copier - how can I change the paper select
Tray 2 from LGL to 11x17?
  • Anonymous Mar 22, 2014
    How do I set the default paper tray on the canon imagerunner 3035 copier?
  • 318 Answers
There is a blue papersize sellector in the paper cassette with an arrow on it,just move that sellector untill the 11/17 mark.change the paper stops inside the tray to the correct possition and the machine will display the correct paper size option.
Posted on Jun 18, 2009
IMAGERUNNER 2018I. How can I change trays?
hi. when you open that tray in the front upper section there is a slide where you can select the paper size
Nov 30, 2015 | Canon Office Equipment & Supplies
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
I have a Canon ImageRUNNER 3235i black and white copier. I have the Cassette Feeding Unit-Y3 installed allowing two additional trays for legal and 11x17 paper sizes. The problem is that the copier doesn't...
This copier does not recognize the paper size automatically. Open the paper drawer and look at the right hand side you will see a dial, Turn that until the paper size you want aligns with the arrow. This sets the paper size.
Nov 03, 2010 | Canon ImageRUNNER 3235i Black and White...
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
Computer reports print job is going to imagerunner but pringint has stopped. There is paper but screen report receiving data a nd processing, nothing coming out?
Do you have selected right paper format on printer properties on PC? If you have A4 in machine and under print prop eg LTR the machine will report problem.You can then manually select on copier eg tray 1 and copier will print the doc on format from tray 1.
Oct 21, 2009 | Canon imageRUNNER 2270 Copier
Showing change paper size when select LGL size paper in canon ir2016
If you are selecting legal on the screen to copy, then be sure that you have legal paper in the tray for printing and that any tray guides are properly set to reflect this.
Jul 22, 2009 | Canon Office Equipment & Supplies
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 2270 Copier Logo
169 people viewed this question
old marine
old marine
