I have an HP Business Inkjet 1200d which is now flashing the paper feed and paperjam lights every time it is switched on. It is the type with a duplex add-on which allows double-sided printing. There is no paper jam, so what is the problem & how can it be resolved?
  • 2 more comments
  • Nigel Firth Jun 18, 2009
    Have tried looking any paper jam in duplex unit, paper tray & under top cover.
    Hi
    I have inspected the printer very closely & could not find any paper. While dismantled I gently manually fed some thick card through & this seemed to clear it, but as soon as I have tried to print normally with it, it prints the first item & then starts flashing with the jam again.
    Any ideas where we go from here?
    Many thanks
  • Nigel Firth Jun 19, 2009
    Hi
    It turns out it was the paper out sensor which had become unclipped because one side was broken. Hopefully a drop of carefully applied superglue will fix it.
    many thanks for your suggestions
    Thank you for your help
  • 13,433 Answers
Please go over these steps to closely inspect and clean the printer of possible jams or dust that might be giving the error message.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 18, 2009
  • Ekse Jun 18, 2009
    you may have to have the machine serviced by Hp because in that case its not about a paper jam, its a mechanical fault / problem which will need to be looked at and serviced by hp.
    are you on warranty?
  • Ekse Jun 19, 2009
    Alright, do you need anything else?
    Thanks,
    Ekse
  • 483 Answers
as per HP : http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09144&lc=en&cc=us&dlc=&product=59305
we got to have the printer serviced for such errors, however try cleaning th eprint head looking at the thread above, should work.
Fame !
The amber light with the triangle next to it is flashing please help!!!
That is the ATTENTION state. Four things can cause it to flash.
1) empty paper tray
2) door open
3) paper jam
4) misfeed from tray.
Press the GO button(the diamond). If it still doesn't work, check for a paperjam.. Also try printing from the manual feed tray.
Aug 21, 2010 | HP LaserJet 1160 Printer
My 1200 printer had a paper jam with envelope we
me pasa lo mismo, pongo una hoja, la toma, y la saca por arriba, como queriendo sacar la hoja trancada, aunque no termina de escupir toda la hoja, la deja 1 pulgada adentro y se la tengo que sacar de pesado, y la luz de paperjam sigue blinking
May 17, 2010 | HP Business InkJet 1200D Printer
We have installed new inkjet cartridges for the inkjet 1200 printer, however there is no inkflow on the paper when printing documents. Please advise on what to do
Sounds like you need to replace the printheads. The business inkjet printers have seperate ink and prinheads. In home use printer models the printer cartridge is all in one with ink and printhead in one unit.
Oct 03, 2009 | HP Business InkJet 1200D Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
Printor indicator brinking and paper light is always on
Printor indicator light is brinking and Paper indicator light is always on and never disappear even if I feed the paper and push the paper button
Nov 16, 2008 | HP Business Inkjet 1000 - Printer - colour...
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
51 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
