Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
What is petrol mix for Mac cat 330 38cc - McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
How many carbs are in the Meow Mix Pate Toppers cat food?
My opinion Meow Mix is not very good or healthy, it's like fast food. It's only my opinion.
Bad stuff in food
  • ground corn
  • corn meal
  • chicken by-product
  • brewers yeast
  • artificial colors
I think it's 16% carbs Meow Mix Cat Food Reviews Ratings and Analysis
Feb 13, 2014 | Meow Mix Pate Toppers Seafood Medley...
I have an aprilia rx125 2008 & the oil petrol mixing system has been blocked off and now petrol & oil are mixed in the petrol tank, but the bike starts for 3-5seconds then stops & petrol comes out of
Hi Steve, and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
Oleo mac 925 manual how do i fill this is it seperate oil+petrol or is it a two and one mix
Chainsaws are two strokes, the oil pump on the saw is to pump chain oil to the cutter bar, the fuel in the tank should be a 25-1 fuel two stroke oil mix.
Oct 06, 2011 | Garden
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
29 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
