Question about Canon Canoscan 9000f Color Image Scanner
Code 5,205,154 refuses to scan stops
How do i reset code
The obdll code can only be reset by an obdll scanning tool. Did you repair the problem? If not the code will reappear & some mechanics will refuse to do repairs because they can not necessarily guaranty their work. The simple answer is go to a parts store, have them read the code, then have them erase it.
Sep 04, 2015 | Cars & Trucks
How do identify and fix limp mode
Adealer with a system reader will scan your OBD system and give you the codes, identify faulty components and offer to repair..you can refuse the latter offer and do it yourself.
An OBD scan should not be very costly, less than a hundred dollars /ponds.
Jul 20, 2015 | Cars & Trucks
Stopped starting , never ever had a problem starting
Check the battery. They go bad every 2-5 years.
Aug 31, 2014 | 1998 Ford Explorer
CODE 5,205,154 CANNOT SCAN CHECK ORIGINAL
5,205,154 code is the act of scanning paper money and it is not allowed to prevent acts of counterfeiting
Apr 13, 2013 | Canon CanoScan LiDE 70 Flatbed Scanner
Error code E42
Error 42 indicates scanner failure. It is sometimes caused due to loose /
faulty scanner cable that connects scanner to motherboard.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 14, 2013 | Canon PIXMA MP150 All-In-One InkJet...
When i try to scan using my mp250 im getting the error code 5,205,154
Do u have enough ink?
For Canon, if you do not have ink in the cartridge, printer won't let you use the scanner as well.
It's all under same system so either black or color cartridge is short of ink, it naturally happens.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 22, 2011 | Office Equipment & Supplies
My toyota camry v6 1996 model switches off while in motion, but comes on when you re-start it. recently, it went off and refuse to start though the engine kept rolling for a while before it eventually...
this could be a number of things , the first step is to have the computer scanned for codes these codes will help it finding the problem, this may be due to a bad coil or distributor cap. but scan it first, many autopart stores will scan it for free and give you the codes and an idea of the problem, hope this helps.
Nov 08, 2010 | 1997 Toyota Camry
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
Won't scan
The scanning feature is much more sensitive to connection signal strength than the printing function. Make sure the USB connection is firmly in place on both the computer and the MP500. If this doesn't fix the problem I would try a different 6 foot length USB cable.
Jul 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Canon Canoscan 9000f Color Image Scanner Logo
old marine
old marine
